Provides supporting functions for PixelFormat enum. More...
#include <gz/rendering/PixelFormat.hh>
static unsigned int BytesPerChannel (PixelFormat _format)
 Get number of bytes per channel for given format. If an invalid format is given, 0 will be returned. More...
static unsigned int BytesPerPixel (PixelFormat _format)
 Get number of bytes per pixel for given format. If an invalid format is given, 0 will be returned. This is simply the product of GetChannelCount and GetBytesPerChannel. More...
static unsigned int ChannelCount (PixelFormat _format)
 Get number of channels for given format. If an invalid format is given, 0 will be returned. More...
static PixelFormat Enum (const std::string &_name)
 Get enum value by human-readable name. The given string should match watch is returned by GetName. If an invalid name is given, PF_UNKNOWN will be returned. More...
static bool IsValid (PixelFormat _format)
 Determine if given format is valid PixelFormat enum. More...
static unsigned int MemorySize (PixelFormat _format, unsigned int _width, unsigned int _height)
 Get total memory size in bytes for an image with the given format and dimensions. If an invalid format is given, 0 will be returned. This is simply the product of GetBytesPerPixel, _width, and, _height. More...
static std::string Name (PixelFormat _format)
 Get human-readable name for pixel format value. More...
static PixelFormat Sanitize (PixelFormat _format)
 Sanitize given format. If the given value is invalid, PF_UNKNOWN will be returned, otherwise input will be returned unchanged. More...
◆ BytesPerChannel()
static unsigned int BytesPerChannel ( PixelFormat  _format)
static
[in]_formatImage pixel format
The number of bytes per channel
◆ BytesPerPixel()
static unsigned int BytesPerPixel ( PixelFormat  _format)
static
The number of bytes per pixel
◆ ChannelCount()
static unsigned int ChannelCount ( PixelFormat  _format)
static
The channel count
◆ Enum()
static PixelFormat Enum ( const std::string &  _name)
static
[in]_nameName of the pixel format to be retrieved
The specified PixelFormat enum value
◆ IsValid()
static bool IsValid ( PixelFormat  _format)
static
[in]_formatEnum value to be evaluated
◆ MemorySize()
static unsigned int MemorySize ( PixelFormat  _format,
static
[in]_widthImage width in pixels
[in]_heightImage height in pixels
Referenced by BaseCamera< T >::ImageMemorySize().
◆ Name()
static std::string Name ( PixelFormat  _format)
static
The format name
◆ Sanitize()
static PixelFormat Sanitize ( PixelFormat  _format)
static
[in]_formatImage pixel format to be sanitized
The sanitized pixel format
Referenced by BaseRenderTarget< T >::SetFormat().
