#include <BaseSensor.hh>
virtual ~BaseSensor ()
 Set visibility mask. More...
 Get visibility mask. More...
 Sensor. More...
 BaseSensor ()
◆ BaseSensor()
BaseSensor
◆ ~BaseSensor()
~BaseSensor
◆ SetVisibilityMask()
void SetVisibilityMask ( uint32_t  _mask)
[in]_maskVisibility mask
Implements Sensor.
Reimplemented in Ogre2Camera, OgreWideAngleCamera, and OgreCamera.
◆ VisibilityMask()
uint32_t VisibilityMask ( ) const
visibility mask
Implements Sensor.
◆ visibilityMask
