| virtual | ~Ogre2Camera () |
| | Destructor. More...
| virtual math::Color | BackgroundColor () const |
| virtual MaterialPtr | BackgroundMaterial () const |
| | Get the background material of this camera. More...
| virtual Ogre::Camera * | OgreCamera () const override |
| | Access the Ogre::Camera object. More...
| | Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
| Ogre2SelectionBuffer * | SelectionBuffer () const |
| | Get the selection buffer object. More...
| virtual void | SetBackgroundColor (const math::Color &_color) |
| virtual void | SetBackgroundMaterial (MaterialPtr _material) |
| | Set the background material of this camera. More...
| void | SetShadowsDirty () override |
| virtual | ~BaseCamera () |
| | Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
| | Remove all render passes from the camera. More...
| virtual | ~Camera () |
| | Destructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
| virtual | ~Ogre2Sensor () |
| | Destructor. More...
| virtual | ~BaseSensor () |
| virtual | ~Ogre2Node () |
| | Destructor. More...
| | Get a pointer to the underlying scene node. More...
| virtual | ~BaseNode () |
| virtual | ~Ogre2Object () |
| | Destructor. More...
| virtual | ~BaseObject () |
| virtual | ~Ogre2ObjectInterface () |
| virtual Ogre::MovableObject * | OgreMovableObject (const char *_typename) const |
| | Access to an Ogre::MovableObject. More...
