| virtual | ~OgreCamera () |
| virtual math::Color | BackgroundColor () const |
| virtual Ogre::Camera * | Camera () const override |
| | Access the Ogre::Camera object. More...
| double | FarClip () const |
| | Get the far clip distance. More...
| double | NearClip () const |
| | Get the near clip distance. More...
| virtual void | SetBackgroundColor (const math::Color &_color) |
| void | SetVFOV (double cameraVFOV) const |
| virtual | ~BaseCamera () |
| | Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
| | Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
| | Remove all render passes from the camera. More...
| virtual | ~Camera () |
| | Destructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
| virtual | ~OgreSensor () |
| virtual | ~BaseSensor () |
| virtual | ~OgreNode () |
| virtual | ~BaseNode () |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
| virtual | ~OgreObjectInterface () |
| virtual Ogre::MovableObject * | OgreMovableObject (const char *_typename) const |
| | Access to an Ogre::MovableObject. More...
