Ogre implementation of WideAngleCamera. More...
#include <Ogre2WideAngleCamera.hh>
virtual ~Ogre2WideAngleCamera () override
void AddRenderPass (const RenderPassPtr &_pass) override
MaterialPtr BackgroundMaterial () const
 Get the background material of this camera. More...
Ogre::Ray CameraToViewportRay (const math::Vector2d &_screenPos, uint32_t _faceIdx)
 It's the same as calling ogreCamera->getCameraToViewportRay but for the specific _faceIdx. More...
common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
void Copy (Image &_image) const override
 Create a texture. More...
void DestroyTextures ()
 Destroys all textures and workspaces, possibly for recreation. More...
uint32_t EnvTextureSize () const
 Gets the environment texture size. More...
 Render the camera. More...
math::Vector3d Project3d (const math::Vector3d &_pt) const override
 Project 3D world coordinates to screen coordinates. More...
 Remove all render passes from the camera. More...
void RemoveRenderPass (const RenderPassPtr &_pass) override
void SetBackgroundMaterial (MaterialPtr _material)
 Set the background material of this camera. More...
void SetEnvTextureSize (uint32_t _size)
 Sets environment texture size. More...
- Public Member Functions inherited from BaseWideAngleCamera< Ogre2Sensor >
virtual ~BaseWideAngleCamera ()
virtual const CameraLens & Lens () const override
 Get the camera lens used by this wide angle camera. More...
virtual void SetLens (const CameraLens &_lens) override
 Set the camera lens to use for this wide angle camera. More...
- Public Member Functions inherited from WideAngleCamera
virtual ~WideAngleCamera ()
virtual ~Camera ()
 Sensor. More...
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
 Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~Ogre2Node ()
void CreateCamera ()
 Create the camera. More...
void CreateFacesWorkspaces (bool _withMsaa)
 Creates the workspaces & their definitions. More...
void CreateStitchWorkspace ()
 Creates the stitch workspaces & their definitions. More...
void CreateStitchWorkspaceDefinition ()
 Creates the workspace definition for stitch (final) pass, including effects. More...
void CreateWideAngleTexture () override
 Set the camera's render target. More...
void CreateWorkspaceDefinition (bool _withMsaa)
 Creates the workspace definition, including effects. More...
void DestroyFacesWorkspaces ()
 Destroys the workspaces & their definitions. More...
void DestroyRenderTexture ()
 Destroy render texture created by CreateRenderTexture() Note: It's not virtual. More...
void DestroyStitchWorkspace ()
 Destroys the stitch workspaces & their definitions. More...
bool HasTempStitchTexture () const
 Returns true if we have a temp texture for Render passes with WideAngleCameraAfterStitching = true. More...
bool NeedsTempStitchTexture () const
 Returns what HasTempStitchTexture() should return. More...
void SetupMSAA (Ogre::CompositorManager2 *_ogreCompMgr, uint8_t _msaa)
 Changes the Compositor Definition to use the MSAA settings we need. Do not call this if not using MSAA. More...
uint32_t TempStitchTextureChannel () const
void UpdateRenderPasses ()
 Checks if workspace nodes need to be updated since render passes can be toggled at any point. More...
std::string WorkspaceDefinitionName (uint32_t _faceIdx) const
 Returns the workspace name. It's unique for each camera. More...
std::string WorkspaceFinalPassDefinitionName () const
 Returns the workspace name for the final pass that stitches all faces. More...
- Protected Member Functions inherited from BaseWideAngleCamera< Ogre2Sensor >
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseWideAngleCamera< Ogre2Sensor >
CameraLens lens
 Camera lens used by this wide angle camera. More...
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2WideAngleCamera()
Ogre2WideAngleCamera ( )
◆ ~Ogre2WideAngleCamera()
virtual ~Ogre2WideAngleCamera ( )
◆ AddRenderPass()
Reimplemented from BaseCamera< Ogre2Sensor >.
◆ BackgroundMaterial()
MaterialPtr BackgroundMaterial ( ) const
background material
◆ CameraToViewportRay()
Ogre::Ray CameraToViewportRay ( const math::Vector2d &  _screenPos,
uint32_t  _faceIdx
_screenPosScreen space position
_faceIdxFace index in range [0; 6). See RayQuery::SetFromCamera for what each value means
Ogre Ray pointing towards screenPos from the given face idx
◆ ConnectNewWideAngleFrame()
common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Reimplemented from BaseWideAngleCamera< Ogre2Sensor >.
◆ Copy()
void Copy ( Image &  _image) const
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateFacesWorkspaces()
void CreateFacesWorkspaces ( bool  _withMsaa)
[in]_withMsaaWhether the version we're retrieving is the MSAA
◆ CreateRenderTexture()
Create a texture.
◆ CreateStitchWorkspace()
void CreateStitchWorkspace ( )
◆ CreateStitchWorkspaceDefinition()
void CreateStitchWorkspaceDefinition ( )
◆ CreateWideAngleTexture()
void CreateWideAngleTexture ( )
◆ CreateWorkspaceDefinition()
void CreateWorkspaceDefinition ( bool  _withMsaa)
[in]_withMsaaWhether the camera is using MSAA
Reimplemented from Ogre2Node.
◆ DestroyFacesWorkspaces()
void DestroyFacesWorkspaces ( )
◆ DestroyRenderTexture()
void DestroyRenderTexture ( )
◆ DestroyStitchWorkspace()
void DestroyStitchWorkspace ( )
◆ DestroyTextures()
void DestroyTextures ( )
◆ EnvTextureSize()
uint32_t EnvTextureSize ( ) const
Texture size
◆ HasTempStitchTexture()
bool HasTempStitchTexture ( ) const
See description.
◆ NeedsTempStitchTexture()
bool NeedsTempStitchTexture ( ) const
True if there are RenderPases with WideAngleCameraAfterStitching = true. False otherwise.
◆ PostRender()
virtual void PostRender ( )
Render the camera.
◆ Project3d()
math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coordinates
Screen coordinates. Z is the distance of point from camera optical center.
◆ RemoveAllRenderPasses()
void RemoveAllRenderPasses ( )
Implements Camera.
◆ RemoveRenderPass()
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< Ogre2Sensor >.
◆ SetBackgroundMaterial()
void SetBackgroundMaterial ( MaterialPtr  _material)
[in]_materialMaterial to set the background to
◆ SetEnvTextureSize()
void SetEnvTextureSize ( uint32_t  _size)
[in]_sizeTexture size
◆ SetupMSAA()
void SetupMSAA ( Ogre::CompositorManager2 *  _ogreCompMgr,
uint8_t  _msaa
[in]_ogreCompMgrOgre's Compositor Manager
[in]_msaaValue in range [2; 256)
◆ TempStitchTextureChannel()
uint32_t TempStitchTextureChannel ( ) const
Returns which channel kStichTmpTexture should be in. Depends on whether number of render passes with RenderPass::WideAngleCameraAfterStitching == true is odd or even
◆ UpdateRenderPasses()
void UpdateRenderPasses ( )
◆ WorkspaceDefinitionName()
std::string WorkspaceDefinitionName ( uint32_t  _faceIdx) const
[in]_faceIdxFace index in range [0; 6)
Workspace definition's name
◆ WorkspaceFinalPassDefinitionName()
std::string WorkspaceFinalPassDefinitionName ( ) const
