RayQuery Class Referenceabstract
#include <gz/rendering/RayQuery.hh>
virtual ~RayQuery ()
virtual RayQueryResult ClosestPoint (bool _forceSceneUpdate=true)=0
 Get ray direction. More...
 Get ray origin. More...
 Set ray direction. More...
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord)=0
virtual void SetFromCamera (const WideAngleCameraPtr &_camera, uint32_t _faceIdx, const math::Vector2d &_coord)=0
 Create the ray query from WideAngleCamera. More...
 Set ray origin. More...
virtual void SetPreferGpu (bool _preferGpu)=0
 If possible & supported (and user called SetFromCamera()) will use the GPU to perform the ray query. Triangle-level accurate. More...
virtual bool UsesGpu () const =0
 Returns true if the GPU will be used for the next ClosestPoint() call. More...
◆ ~RayQuery()
virtual ~RayQuery ( )
◆ ClosestPoint()
virtual RayQueryResult ClosestPoint ( bool  _forceSceneUpdate = true)
[in]_forceSceneUpdatePerformance optimization hint When true Ogre2 will update all derived transforms to their latest to get correct results.
When false, that step is skipped. It is only safe to set it to false when nothing has changed since the last update (i.e. nothing moved, no new objects created).
Ogre will assert if built in Debug mode if this value is set to false when it shouldn't be.
See https://ogrecave.github.io/ogre-next/api/2.2/ _ogre20_changes.html::AssersionCachedOutOfDate for more info
Implemented in Ogre2RayQuery, OgreRayQuery, BaseRayQuery< T >, BaseRayQuery< Ogre2Object >, and BaseRayQuery< OgreObject >.
◆ Direction()
Get ray direction.
Ray direction.
Implemented in BaseRayQuery< T >, BaseRayQuery< Ogre2Object >, and BaseRayQuery< OgreObject >.
◆ Origin()
virtual math::Vector3d Origin ( ) const
Get ray origin.
Ray origin
◆ SetDirection()
Set ray direction.
[in]_dirRay origin
◆ SetFromCamera() [1/2]
◆ SetFromCamera() [2/2]
virtual void SetFromCamera ( const WideAngleCameraPtr &  _camera,
uint32_t  _faceIdx,
[in]_faceIdxIn range [0; 6)
  • 0 = +X
  • 1 = -X
  • 2 = +Y
  • 3 = -Y
  • 4 = +Z
  • 5 = -Z
Implemented in Ogre2RayQuery, and OgreRayQuery.
◆ SetOrigin()
virtual void SetOrigin ( const math::Vector3d &  _origin)
Set ray origin.
[in]_originRay origin
◆ SetPreferGpu()
virtual void SetPreferGpu ( bool  _preferGpu)
Remarks
It's not guaranteed the GPU will be used. See UsesGpu()
Using the GPU is not necessarily faster.
[in]_preferGpuTrue to use the GPU if available & possible. False to never use the GPU.
Implemented in Ogre2RayQuery, BaseRayQuery< T >, BaseRayQuery< Ogre2Object >, and BaseRayQuery< OgreObject >.
◆ UsesGpu()
virtual bool UsesGpu ( ) const
Remarks
The thread ID is important. Calling this value from different threads may result in different return values.
True if next ClosestPoint() call will use the GPU.
