Generate depth ray data. More...
#include <gz/rendering/GpuRays.hh>
Public Types | |
| virtual | ~GpuRays () |
| Destructor. More... | |
| virtual gz::math::Angle | AngleMax () const =0 |
| Get maximal horizontal angle value. More... | |
| virtual gz::math::Angle | AngleMin () const =0 |
| Get minimal horizontal angle value. More... | |
| virtual unsigned int | Channels () const =0 |
| Get the number of channels used to store the ray data. More... | |
| virtual bool | Clamp () const =0 |
| Get behaviour for data values outside of camera range. More... | |
| virtual common::ConnectionPtr | ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &)> _subscriber)=0 |
| Connect to a gpu rays frame signal. More... | |
| virtual void | Copy (float *_data)=0 |
| Copy to the specified memory direction the gpu rays data. More... | |
| virtual const float * | Data () const =0 |
| All things needed to get back z buffer for gpu rays data. More... | |
| virtual double | HorizontalResolution () const =0 |
| Get the horizontal resolution. This number is multiplied by RayCount to calculate RangeCount, which is the the number range data points. More... | |
| virtual bool | IsHorizontal () const =0 |
| Gets if sensor is horizontal. More... | |
| virtual int | RangeCount () const =0 |
| Get hoizontal range count, i.e. ray count * horz resolution. More... | |
| virtual double | RangeCountRatio () const =0 |
| Get the ray count ratio (equivalent to aspect ratio) More... | |
| virtual int | RayCount () const =0 |
| Get horizontal quantity of rays. More... | |
| virtual double | RayCountRatio () const =0 |
| virtual void | SetAngleMax (double _angle)=0 |
| Set maximal horizontal angle value. More... | |
| virtual void | SetAngleMin (double _angle)=0 |
| Set minimal horizontal angle value. More... | |
| virtual void | SetClamp (const bool _clamp)=0 |
| Configure behaviour for data values outside of camera range. More... | |
| virtual void | SetHorizontalResolution (double _resolution)=0 |
| Set the horizontal resolution. This number is multiplied by RayCount to calculate RangeCount, which is the the number range data points. More... | |
| virtual void | SetIsHorizontal (const bool _horizontal)=0 |
| Set sensor horizontal or vertical. More... | |
| virtual void | SetRayCount (int _samples)=0 |
| Set horizontal quantity of rays. More... | |
| virtual void | SetRayCountRatio (const double _rayCountRatio)=0 |
| Sets the ray count ratio (equivalent to aspect ratio) More... | |
| virtual void | SetVerticalAngleMax (const double _angle)=0 |
| Set maximal vertical angle value. More... | |
| virtual void | SetVerticalAngleMin (const double _angle)=0 |
| Set minimal vertical angle value. More... | |
| virtual void | SetVerticalRayCount (int _samples)=0 |
| Set vertical quantity of rays. More... | |
| virtual void | SetVerticalResolution (double _resolution)=0 |
| Set the vertical resolution. This number is multiplied by VerticalRayCount to calculate VerticalRangeCount, which is the the number vertical range data points. More... | |
| virtual gz::math::Angle | VerticalAngleMax () const =0 |
| Get maximal vertical angle value. More... | |
| virtual gz::math::Angle | VerticalAngleMin () const =0 |
| Get minimal vertical angle value. More... | |
| virtual int | VerticalRangeCount () const =0 |
| Get vertical range count, i.e. ray count * vert resolution. More... | |
| virtual int | VerticalRayCount () const =0 |
| Get vertical quantity of rays. More... | |
| virtual double | VerticalResolution () const =0 |
| Get the vertical resolution. This number is multiplied by VerticalRayCount to calculate VerticalRangeCount, which is the the number vertical range data points. More... | |
| virtual math::Angle | VFOV () const =0 |
| Get the vertical field-of-view. More... | |
| virtual | ~Camera () |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| Writes the last rendered image into a caller owned buffer, for example a message payload, without an intermediate copy. Like Copy, this can be called any number of times after PostRender. The buffer must match the camera's image size and be at least _buffer.MemorySize() bytes. Nothing keeps a pointer to the buffer once this call returns. More... | |
| Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More... | |
| virtual void | PrepareForExternalSampling ()=0 |
| Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More... | |
| virtual void | RemoveAllRenderPasses ()=0 |
| Remove all render passes from the camera. More... | |
| virtual void | RenderTextureMetalId (void *_textureIdPtr) const =0 |
| Get the Metal texture id associated with the render texture used by this camera. A valid Id is obtained only if the underlying render engine is Metal based. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. More... | |
| virtual void | SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0 |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
Member Typedef Documentation
◆ NewFrameListener
| typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener |
◆ ~GpuRays()
virtual |
◆ AngleMax()
pure virtual |
Implemented in BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, and BaseGpuRays< OgreSensor >.
◆ AngleMin()
pure virtual |
◆ Channels()
pure virtual |
- Returns
- Channel count.
◆ Clamp()
pure virtual |
- Returns
- True if data values are clampped to camera clip distances,
◆ ConnectNewGpuRaysFrame()
pure virtual |
[in] _subscriber Callback that is called when a new image is generated. The callback function parameters are: _frame: Image frame is an array of floats. Size is equal to width * height * channels Each gpu rays reading occupies 3 floats Index 0: depth value Index 1: retro value Index 2: 0. Not used _width: Width of image, i.e. number of data in the horizontal scan _height: Height o image, i.e. number of scans in vertical direction _channels: Number of channels, i.e. 3 floats per gpu rays reading _format: Pixel format of the image frame.
- Returns
- A pointer to the connection. This must be kept in scope.
◆ Copy()
pure virtual |
Implemented in BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, BaseGpuRays< OgreSensor >, Ogre2GpuRays, and OgreGpuRays.
◆ Data()
pure virtual |
- Returns
- Array of gpu rays data.
Implemented in Ogre2GpuRays, OgreGpuRays, BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, and BaseGpuRays< OgreSensor >.
◆ HorizontalResolution()
pure virtual |
- See also
- RayCount()
- Returns
- The horizontal resolution
◆ IsHorizontal()
pure virtual |
- Returns
- True if horizontal, false if not
◆ RangeCount()
pure virtual |
◆ RangeCountRatio()
pure virtual |
- Returns
- The ray count ratio (equivalent to aspect ratio)
◆ RayCount()
pure virtual |
◆ RayCountRatio()
pure virtual |
- Returns
◆ SetAngleMax()
pure virtual |
◆ SetAngleMin()
pure virtual |
◆ SetClamp()
pure virtual |
[in] _clamp True to clamp data to camera clip distances,
◆ SetHorizontalResolution()
pure virtual |
- See also
- RayCount()
[in] _resolution The new horizontal resolution. The absolute value of this parameter is used to prevent a negative resolution value.
◆ SetIsHorizontal()
pure virtual |
[in] _horizontal True if horizontal, false if not
◆ SetRayCount()
pure virtual |
◆ SetRayCountRatio()
pure virtual |
[in] _rayCountRatio ray count ratio (equivalent to aspect ratio)
◆ SetVerticalAngleMax()
pure virtual |
◆ SetVerticalAngleMin()
pure virtual |
◆ SetVerticalRayCount()
pure virtual |
◆ SetVerticalResolution()
pure virtual |
[in] _resolution The new vertical resolution. The absolute value of this parameter is used to prevent a negative resolution value.
- See also
- VerticalRayCount()
◆ VerticalAngleMax()
pure virtual |
◆ VerticalAngleMin()
pure virtual |
◆ VerticalRangeCount()
pure virtual |
◆ VerticalRayCount()
pure virtual |
◆ VerticalResolution()
pure virtual |
- Returns
- The vertical resolution.
- See also
◆ VFOV()
pure virtual |
- Returns
- The vertical field of view of the gpu rays.
