#include <Ogre2JointVisual.hh>
virtual ~Ogre2JointVisual ()
- Public Member Functions inherited from BaseJointVisual< Ogre2Visual >
virtual ~BaseJointVisual ()
virtual gz::math::Vector3d Axis () const override
 Get axis vector. More...
virtual gz::math::Vector3d ParentAxis () const override
virtual void SetAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
virtual void SetParentAxis (const gz::math::Vector3d &_axis, const std::string &_parentName, bool _useParentFrame) override
virtual bool UpdateAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
virtual bool UpdateParentAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
virtual ~JointVisual ()
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2JointVisual ()
- Protected Member Functions inherited from BaseJointVisual< Ogre2Visual >
 BaseJointVisual ()
void CreateAxis ()
void CreateParentAxis ()
void ScaleToChild ()
void UpdateAxisImpl (ArrowVisualPtr _arrowVisual, const gz::math::Vector3d &_axis, bool _useParentFrame)
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseJointVisual< Ogre2Visual >
ArrowVisualPtr arrowVisual
gz::math::Vector3d axis
AxisVisualPtr axisVisual
bool dirtyAxis
bool dirtyJointType
bool dirtyParentAxis
std::string jointParentName
 Joint parent name. More...
gz::math::Vector3d parentAxis
 Parent axis vector. More...
bool parentAxisUseParentFrame
JointVisualPtr parentAxisVis
gz::math::Vector3d scaleToChild
bool updateAxis
bool updateParentAxis
bool useParentFrame
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2JointVisual()
Ogre2JointVisual ( )
◆ ~Ogre2JointVisual()
virtual ~Ogre2JointVisual ( )
