#include <Ogre2Marker.hh>
virtual ~Ogre2Marker ()
 Destroy function. More...
 PreRender function. More...
- Public Member Functions inherited from BaseMarker< Ogre2Geometry >
virtual ~BaseMarker ()
virtual ~Marker ()
virtual ~Ogre2Geometry ()
 ~BaseGeometry () override
 Clone the geometry. More...
void RemoveParent () override
 Ogre2Marker ()
- Protected Member Functions inherited from BaseMarker< Ogre2Geometry >
 BaseMarker ()
 Marker ()
 Ogre2Geometry ()
 BaseGeometry ()
- Protected Attributes inherited from BaseMarker< Ogre2Geometry >
int32_t layer
bool markerDirty
MarkerType markerType
 Marker type. More...
double size
 Marker size. More...
Ogre2VisualPtr parent
 Parent visual. More...
◆ Ogre2Marker()
Ogre2Marker ( )
◆ ~Ogre2Marker()
virtual ~Ogre2Marker ( )
◆ AddPoint()
Reimplemented from BaseMarker< Ogre2Geometry >.
◆ ClearPoints()
virtual void ClearPoints ( )
Destroy function.
Implements Geometry.
◆ OgreObject()
Implements Ogre2Geometry.
PreRender function.
◆ SetMaterial()
bool  _unique
◆ SetPoint()
◆ SetType()
◆ Type()
The render type of the marker
