BaseGeometry< T > Class Template Referenceabstract
#include <BaseGeometry.hh>
 ~BaseGeometry () override
 Clone the geometry. More...
void Destroy () override
VisualPtr Parent () const override=0
void RemoveParent () override
void SetMaterial (MaterialPtr _material, bool _unique=true) override=0
 BaseGeometry ()
◆ BaseGeometry()
BaseGeometry
◆ ~BaseGeometry()
~BaseGeometry
◆ Clone()
GeometryPtr Clone ( ) const
Clone the geometry.
The cloned geometry.
Implements Geometry.
Reimplemented in BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
References gzwarn.
void Destroy ( )
Reimplemented in BaseWireBox< Ogre2Geometry >, BaseWireBox< OgreGeometry >, BaseText< OgreGeometry >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, BaseMarker< Ogre2Geometry >, BaseMarker< OgreGeometry >, BaseHeightmap< Ogre2Geometry >, BaseHeightmap< OgreGeometry >, BaseGrid< Ogre2Geometry >, and BaseGrid< OgreGeometry >.
◆ Parent()
VisualPtr Parent ( ) const
overridepure virtual
the parent Visual
Implemented in Ogre2Geometry, and OgreGeometry.
◆ RemoveParent()
void RemoveParent ( )
◆ SetMaterial() [1/2]
bool  _unique = true
References Scene::Material().
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, Ogre2WireBox, Ogre2Marker, Ogre2Heightmap, Ogre2Grid, Ogre2Capsule, OgreWireBox, OgreText, OgreMarker, OgreHeightmap, OgreGrid, and OgreCapsule.
