#include <OgreLight.hh>
 ~OgreLight () override
void SetAttenuationConstant (double _value) override
void SetAttenuationLinear (double _value) override
void SetAttenuationQuadratic (double _value) override
void SetAttenuationRange (double _range) override
void SetCastShadows (bool _castShadows) override
void SetDiffuseColor (const math::Color &_color) override
void SetSpecularColor (const math::Color &_color) override
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~Light ()
virtual ~OgreNode ()
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreLight()
OgreLight ( )
◆ ~OgreLight()
~OgreLight ( )
◆ AttenuationConstant()
Implements Light.
◆ AttenuationLinear()
The attenuation linear value
Implements Light.
◆ AttenuationQuadratic()
Implements Light.
◆ AttenuationRange()
The attenuation range
Implements Light.
◆ CastShadows()
Implements Light.
Reimplemented from OgreNode.
◆ DiffuseColor()
The diffuse color
Implements Light.
◆ Intensity()
virtual double Intensity ( ) const
The light intensity
Implements Light.
◆ Light()
virtual Ogre::Light* Light ( ) const
◆ SetAttenuationConstant()
void SetAttenuationConstant ( double  _value)
Implements BaseLight< OgreNode >.
◆ SetAttenuationLinear()
void SetAttenuationLinear ( double  _value)
◆ SetAttenuationQuadratic()
void SetAttenuationQuadratic ( double  _value)
◆ SetAttenuationRange()
void SetAttenuationRange ( double  _range)
◆ SetCastShadows()
void SetCastShadows ( bool  _castShadows)
◆ SetDiffuseColor()
void SetDiffuseColor ( const math::Color &  _color)
[in]_colorNew diffuse color
◆ SetIntensity()
virtual void SetIntensity ( double  _intensity)
[in]_intensityNew light intensity
Implements Light.
◆ SetSpecularColor()
void SetSpecularColor ( const math::Color &  _color)
[in]_colorNew specular color
◆ SpecularColor()
The specular color
Implements Light.
◆ attenConstant
◆ attenLinear
double attenLinear
◆ attenQuadratic
◆ attenRange
double attenRange
◆ ogreLight
Ogre::Light* ogreLight
◆ ogreLightType
