BaseLight< T > Class Template Referenceabstract
#include <BaseLight.hh>
 ~BaseLight () override
void SetAttenuationConstant (double _value) override=0
void SetAttenuationLinear (double _value) override=0
void SetAttenuationQuadratic (double _value) override=0
void SetAttenuationRange (double _range) override=0
void SetCastShadows (bool _castShadows) override=0
void SetDiffuseColor (const math::Color &_color) override=0
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (const math::Color &_color) override=0
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~Light ()
 BaseLight ()
◆ BaseLight()
BaseLight
◆ ~BaseLight()
~BaseLight
◆ Reset()
◆ SetAttenuationConstant()
void SetAttenuationConstant ( double  _value)
overridepure virtual
Implements Light.
Implemented in Ogre2Light, and OgreLight.
◆ SetAttenuationLinear()
void SetAttenuationLinear ( double  _value)
Implements Light.
◆ SetAttenuationQuadratic()
void SetAttenuationQuadratic ( double  _value)
Implements Light.
◆ SetAttenuationRange()
void SetAttenuationRange ( double  _range)
Implements Light.
◆ SetCastShadows()
void SetCastShadows ( bool  _castShadows)
Implements Light.
◆ SetDiffuseColor() [1/2]
void SetDiffuseColor ( const math::Color &  _color)
[in]_colorNew diffuse color
Implements Light.
◆ SetDiffuseColor() [2/2]
void SetDiffuseColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Implements Light.
◆ SetSpecularColor() [1/2]
void SetSpecularColor ( const math::Color &  _color)
[in]_colorNew specular color
Implements Light.
◆ SetSpecularColor() [2/2]
void SetSpecularColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Implements Light.
