BaseDirectionalLight< T > Class Template Referenceabstract
#include <BaseLight.hh>
 ~BaseDirectionalLight () override
void SetDirection (const math::Vector3d &_dir) override=0
void SetDirection (double _x, double _y, double _z) override
- Public Member Functions inherited from DirectionalLight
virtual ~DirectionalLight ()
virtual ~Light ()
void Reset () override
◆ BaseDirectionalLight()
◆ ~BaseDirectionalLight()
◆ Reset()
void Reset
overrideprotected
◆ SetDirection() [1/2]
overridepure virtual
[in]_dirNew direction vector
Implements DirectionalLight.
Implemented in Ogre2DirectionalLight, and OgreDirectionalLight.
◆ SetDirection() [2/2]
void SetDirection ( double  _x,
double  _y,
double  _z
