#include <OgreLight.hh>
 ~OgreDirectionalLight () override
math::Vector3d Direction () const override
void SetDirection (const math::Vector3d &_dir) override
- Public Member Functions inherited from BaseDirectionalLight< OgreLight >
 ~BaseDirectionalLight () override
void SetDirection (double _x, double _y, double _z) override
- Public Member Functions inherited from DirectionalLight
virtual ~DirectionalLight ()
virtual ~Light ()
 ~OgreLight () override
void SetAttenuationConstant (double _value) override
void SetAttenuationLinear (double _value) override
void SetAttenuationQuadratic (double _value) override
void SetAttenuationRange (double _range) override
void SetCastShadows (bool _castShadows) override
void SetDiffuseColor (const math::Color &_color) override
void SetSpecularColor (const math::Color &_color) override
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~OgreNode ()
- Protected Member Functions inherited from BaseDirectionalLight< OgreLight >
void Reset () override
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreDirectionalLight()
OgreDirectionalLight ( )
◆ ~OgreDirectionalLight()
~OgreDirectionalLight ( )
◆ Direction()
math::Vector3d Direction ( ) const
The direction of the light
Implements DirectionalLight.
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseDirectionalLight< OgreLight >.
