BaseSpotLight< T > Class Template Referenceabstract
#include <BaseLight.hh>
 ~BaseSpotLight () override
void SetDirection (const math::Vector3d &_dir) override=0
void SetDirection (double _x, double _y, double _z) override
void SetFalloff (double _falloff) override=0
void SetInnerAngle (const math::Angle &_angle) override=0
void SetInnerAngle (double _radians) override
void SetOuterAngle (const math::Angle &_angle) override=0
void SetOuterAngle (double _radians) override
virtual ~SpotLight ()
virtual ~Light ()
 BaseSpotLight ()
void Reset () override
◆ BaseSpotLight()
BaseSpotLight
◆ ~BaseSpotLight()
~BaseSpotLight
◆ Reset()
void Reset
overrideprotected
References GZ_PI.
◆ SetDirection() [1/2]
overridepure virtual
[in]_dirNew direction vector
Implements SpotLight.
◆ SetDirection() [2/2]
void SetDirection ( double  _x,
double  _y,
double  _z
◆ SetFalloff()
void SetFalloff ( double  _falloff)
◆ SetInnerAngle() [1/2]
void SetInnerAngle ( const math::Angle &  _angle)
◆ SetInnerAngle() [2/2]
void SetInnerAngle ( double  _radians)
◆ SetOuterAngle() [1/2]
void SetOuterAngle ( const math::Angle &  _angle)
◆ SetOuterAngle() [2/2]
void SetOuterAngle ( double  _radians)
