#include <OgreLight.hh>
 ~OgreSpotLight () override
math::Vector3d Direction () const override
double Falloff () const override
math::Angle InnerAngle () const override
math::Angle OuterAngle () const override
void SetDirection (const math::Vector3d &_dir) override
void SetFalloff (double _falloff) override
void SetInnerAngle (const math::Angle &_angle) override
void SetOuterAngle (const math::Angle &_angle) override
- Public Member Functions inherited from BaseSpotLight< OgreLight >
 ~BaseSpotLight () override
void SetDirection (double _x, double _y, double _z) override
void SetInnerAngle (double _radians) override
void SetOuterAngle (double _radians) override
virtual ~SpotLight ()
virtual ~Light ()
 ~OgreLight () override
void SetAttenuationConstant (double _value) override
void SetAttenuationLinear (double _value) override
void SetAttenuationQuadratic (double _value) override
void SetAttenuationRange (double _range) override
void SetCastShadows (bool _castShadows) override
void SetDiffuseColor (const math::Color &_color) override
void SetSpecularColor (const math::Color &_color) override
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~OgreNode ()
 OgreSpotLight ()
- Protected Member Functions inherited from BaseSpotLight< OgreLight >
 BaseSpotLight ()
void Reset () override
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreSpotLight()
OgreSpotLight ( )
◆ ~OgreSpotLight()
~OgreSpotLight ( )
◆ Direction()
math::Vector3d Direction ( ) const
The direction of the light
Implements SpotLight.
◆ Falloff()
double Falloff ( ) const
The falloff of the spotlight
◆ InnerAngle()
math::Angle InnerAngle ( ) const
◆ OuterAngle()
math::Angle OuterAngle ( ) const
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseSpotLight< OgreLight >.
◆ SetFalloff()
void SetFalloff ( double  _falloff)
◆ SetInnerAngle()
void SetInnerAngle ( const math::Angle &  _angle)
◆ SetOuterAngle()
void SetOuterAngle ( const math::Angle &  _angle)
