Ogre 1.x implementation of a Projector class. More...
#include <OgreProjector.hh>
virtual ~OgreProjector ()
 Set whether the projector is enabled or disabled. More...
- Public Member Functions inherited from BaseProjector< OgreVisual >
virtual ~BaseProjector ()
 Get the projector's far clipping plane distance. More...
 Get the projector's horizontal field-of-view. More...
bool IsEnabled () const override
 Get whether the projector is enabled or disabled. More...
 Get the projector's near clipping plane distance. More...
virtual void SetFarClipPlane (double _far) override
 Set the projector's far clipping plane distance. More...
 Set the projector's horizontal field-of-view. More...
virtual void SetNearClipPlane (double _near) override
 Set the projector's near clipping plane distance. More...
void SetTexture (const std::string &_texture) override
 Load a texture into the projector. More...
 Get the URI of the texture file used by the projector. More...
- Public Member Functions inherited from Projector
virtual ~Projector ()
virtual ~OgreVisual ()
virtual ~BaseVisual ()
virtual ~OgreNode ()
 OgreProjector ()
- Protected Member Functions inherited from BaseProjector< OgreVisual >
 BaseProjector ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseProjector< OgreVisual >
bool enabled
 Indicates whether or not the projector is enabled. More...
double farClip
 Projector's far clip plane. More...
math::Angle hfov
 Projector's horizontal field of view. More...
double nearClip
 Projector's near clip plane. More...
std::string textureName
 Texture used by the projector. More...
uint32_t visibilityFlags
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreProjector()
OgreProjector ( )
◆ ~OgreProjector()
virtual ~OgreProjector ( )
Reimplemented from BaseVisual< OgreNode >.
◆ SetEnabled()
[in]_enabledTrue to enable the projector.
Implements Projector.
