Ogre2SelectionBuffer Class Reference
Generates a selection buffer object for a given camera. The selection buffer is used of entity selection. On setup, a unique color is assigned to each entity. Whenever a selection request is made, the selection buffer camera renders to a 1x1 sized offscreen buffer. The color value of that pixel gives the identity of the entity. More...
#include <Ogre2SelectionBuffer.hh>
 Ogre2SelectionBuffer (const std::string &_cameraName, Ogre2ScenePtr _scene, unsigned int _width, unsigned int _height)
 ~Ogre2SelectionBuffer ()
bool ExecuteQuery (const int _x, const int _y, Ogre::Item *&_item, math::Vector3d &_point)
 Perform selection operation and get ogre item and point of intersection.
bool ExecuteQuery (int _x, int _y, Ogre::MovableObject *&_obj, math::Vector3d &_point)
Ogre::MovableObject * OnSelectionClick (int _x, int _y)
 Handle on mouse click.
void SetDimensions (unsigned int _width, unsigned int _height)
 Set dimension of the selection buffer.
void Update ()
 Call this to update the selection buffer contents.
◆ Ogre2SelectionBuffer()
Ogre2SelectionBuffer ( const std::string &  _cameraName,
[in]_cameraNameName of the camera to generate a selection buffer for.
[in]_widthwidth of the camera
[in]_heightheight of the camera
◆ ~Ogre2SelectionBuffer()
◆ ExecuteQuery() [1/2]
bool ExecuteQuery ( const int  _x,
const int  _y,
Ogre::Item *&  _item,
math::Vector3d &  _point
[in]_xX coordinate in pixels.
[in]_yY coordinate in pixels.
[out]_itemOgre item at the coordinate.
[out]_point3D point of intersection with the ogre item's mesh.
True if an ogre item is found, false otherwise
◆ ExecuteQuery() [2/2]
bool ExecuteQuery ( int  _x,
int  _y,
Ogre::MovableObject *&  _obj,
[out]_objOgre movable object at the coordinate.
[out]_point3D point of intersection with the ogre object.
True if an ogre object is found, false otherwise
◆ OnSelectionClick()
Ogre::MovableObject * OnSelectionClick ( int  _x,
int  _y
Returns the Ogre movable object at the coordinate.
◆ SetDimensions()
void SetDimensions ( unsigned int  _width,
[in]_widthX dimension in pixels.
[in]_heightY dimension in pixels.
void Update ( )
