Collection of render-engines. This provides access to all the render-engines available at runtime. RenderEngine objects should not be access directly, but instead via the RenderEngineManager to maintain a flexible render-engine agnostic design. More...
#include <RenderEngineManager.hh>
 RenderEngineManager ()
 ~RenderEngineManager ()
RenderEngine * Engine (const std::string &_name, const std::map< std::string, std::string > &_params={}, const std::string &_path="")
 Get the render-engine with the given name. If the no render-engine is registered under the given name, NULL will be returned.
RenderEngine * EngineAt (unsigned int _index, const std::map< std::string, std::string > &_params={}, const std::string &_path="")
 Get the render-engine at the given index. If no render-engine is exists at the given index, NULL will be returned.
unsigned int EngineCount () const
 Get the number of available render-engines.
bool HasEngine (const std::string &_name) const
 Determine if a render-engine with the given name is available. It also checks the list of default engines supplied by gz-rendering.
bool IsEngineLoaded (const std::string &_name) const
 Determine if a render-engine with the given name is already loaded.
std::vector< std::string > LoadedEngines () const
 Get the list of all engines already loaded.
void RegisterEngine (const std::string &_name, RenderEngine *_engine)
 Register a new render-engine under the given name. If the given name is already in use, the render-engine will not be registered.
void SetPluginPaths (const std::list< std::string > &_paths)
 Set the plugin paths from which render engines can be loaded.
bool UnloadEngine (const std::string &_name)
 Unload the render-engine with the given name. If the no render-engine is registered under the given name, false will be returned.
bool UnloadEngineAt (unsigned int _index)
 Unload the render-engine at the given index. If the no render-engine is registered under the given name, false will be returned.
void UnregisterEngine (const std::string &_name)
 Unregister a render-engine registered under the given name. If no render-engine is registered under the given name no work will be done.
void UnregisterEngine (RenderEngine *_engine)
 Unregister the given render-engine. If the given render-engine is not currently registered, no work will be done.
void UnregisterEngineAt (unsigned int _index)
 Unregister a render-engine at the given index. If the no render-engine is registered at the given index, no work will be done.
static RenderEngineManager * Instance ()
 Get a pointer to the render engine manager.
gz/rendering/RenderEngineManager.hh
◆ RenderEngineManager()
◆ ~RenderEngineManager()
◆ Engine()
RenderEngine * Engine ( const std::string &  _name,
const std::map< std::string, std::string > &  _params = {},
const std::string &  _path = ""
[in]_nameName of the desired render-engine
[in]_pathAnother search path for rendering engine plugin.
The specified render-engine
◆ EngineAt()
RenderEngine * EngineAt ( unsigned int  _index,
[in]_indexIndex of the desired render-engine
◆ EngineCount()
unsigned int EngineCount ( ) const
◆ HasEngine()
bool HasEngine ( const std::string &  _name) const
True if the specified render-engine is available
◆ Instance()
static RenderEngineManager * Instance ( )
static
◆ IsEngineLoaded()
bool IsEngineLoaded ( const std::string &  _name) const
True if the specified render-engine is loaded.
◆ LoadedEngines()
std::vector< std::string > LoadedEngines ( ) const
Names of all loaded engines.
◆ RegisterEngine()
void RegisterEngine ( const std::string &  _name,
RenderEngine *  _engine
[in]_nameName the render-engine will be registered under
[in]_engineRender-engine to be registered
◆ SetPluginPaths()
void SetPluginPaths ( const std::list< std::string > &  _paths)
[in]_pathsThe list of the plugin paths
◆ UnloadEngine()
bool UnloadEngine ( const std::string &  _name)
True if the engine is unloaded
◆ UnloadEngineAt()
bool UnloadEngineAt ( unsigned int  _index)
◆ UnregisterEngine() [1/2]
void UnregisterEngine ( const std::string &  _name)
[in]_nameName of the render-engine to unregister
◆ UnregisterEngine() [2/2]
void UnregisterEngine ( RenderEngine *  _engine)
[in]_engineRender-engine to unregister
◆ UnregisterEngineAt()
void UnregisterEngineAt ( unsigned int  _index)
[in]_indexIndex of the render-engine to unregister
