Gazebo Sensors
gz/sensors/AltimeterSensor.hh
16 */
17 #ifndef GZ_SENSORS_ALTIMETERSENSOR_HH_
18 #define GZ_SENSORS_ALTIMETERSENSOR_HH_
20 #include <memory>
21
22 #include <sdf/sdf.hh>
23
24 #include <gz/common/SuppressWarning.hh>
25
26 #include <gz/sensors/config.hh>
27 #include <gz/sensors/altimeter/Export.hh>
28
29 #include "gz/sensors/Sensor.hh"
30
31 namespace ignition
32 {
33  namespace sensors
34  {
35  // Inline bracket to help doxygen filtering.
36  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
37  //
39  class AltimeterSensorPrivate;
40
45  class IGNITION_SENSORS_ALTIMETER_VISIBLE AltimeterSensor : public Sensor
46  {
48  public: AltimeterSensor();
49
51  public: virtual ~AltimeterSensor();
52
56  public: virtual bool Load(const sdf::Sensor &_sdf) override;
57
61  public: virtual bool Load(sdf::ElementPtr _sdf) override;
62
65  public: virtual bool Init() override;
66
70  public: virtual bool Update(
71  const std::chrono::steady_clock::duration &_now) override;
72
75  public: void SetVerticalReference(double _reference);
76
79  public: double VerticalReference() const;
80
83  public: void SetPosition(double _pos);
84
88  public: double VerticalPosition() const;
89
92  public: void SetVerticalVelocity(double _vel);
93
96  public: double VerticalVelocity() const;
97
101  public: bool HasConnections() const;
102
103  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
107  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
108  };
109  }
110  }
111 }
112
113 #endif
Altimeter Sensor Class.
Definition: gz/sensors/AltimeterSensor.hh:46
destructor
Set the current z position of the altimeter.
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
Get the vertical position of the altimeter relative to the reference position.
Set the vertical velocity of the altimeter.
Set the vertical reference position of the altimeter.
Get the vertical velocity of the altimeter.
Get the vertical reference position of the altimeter.
a base sensor class
Definition: gz/sensors/Sensor.hh:60
