Gazebo Sensors
gz/sensors/NavSatSensor.hh
16 */
17 #ifndef IGNITION_SENSORS_NAVSAT_HH_
18 #define IGNITION_SENSORS_NAVSAT_HH_
20 #include <memory>
21
22 #include <ignition/common/SuppressWarning.hh>
23 #include <sdf/Sensor.hh>
24
25 #include "gz/sensors/config.hh"
26 #include "gz/sensors/navsat/Export.hh"
27
29
30 namespace ignition
31 {
32  namespace sensors
33  {
34  // Inline bracket to help doxygen filtering.
35  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
36  //
38  class NavSatPrivate;
39
49  class IGNITION_SENSORS_NAVSAT_VISIBLE NavSatSensor : public Sensor
50  {
52  public: NavSatSensor();
53
55  public: virtual ~NavSatSensor();
56
60  public: virtual bool Load(const sdf::Sensor &_sdf) override;
61
65  public: virtual bool Load(sdf::ElementPtr _sdf) override;
66
69  public: virtual bool Init() override;
70
74  public: virtual bool Update(
75  const std::chrono::steady_clock::duration &_now) override;
76
79  public: void SetLatitude(const math::Angle &_latitude);
80
84  public: const math::Angle &Latitude() const;
85
88  public: void SetLongitude(const math::Angle &_longitude);
89
93  public: const math::Angle &Longitude() const;
94
97  public: void SetAltitude(double _altitude);
98
101  public: double Altitude() const;
102
105  public: void SetVelocity(const math::Vector3d &_vel);
106
109  public: const math::Vector3d &Velocity() const;
110
114  public: bool HasConnections() const;
115
120  public: void SetPosition(const math::Angle &_latitude,
121  const math::Angle &_longitude, double _altitude = 0.0);
122
123  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
126  private: std::unique_ptr<NavSatPrivate> dataPtr;
127  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
128  };
129  }
130  }
131 }
132
133 #endif
NavSat Sensor Class.
Definition: gz/sensors/NavSatSensor.hh:50
const math::Angle & Longitude() const
Get the longitude of the NavSat, wrapped between +/- 180 degrees.
Set the altitude of the NavSat.
Set the velocity of the NavSat in ENU world frame.
Get NavSat altitude above sea level.
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
Set the latitude of the NavSat.
void SetPosition(const math::Angle &_latitude, const math::Angle &_longitude, double _altitude=0.0)
Easy short hand for setting the position of the sensor.
Set the longitude of the NavSat.
const math::Angle & Latitude() const
Get the latitude of the NavSat, wrapped between +/- 180 degrees.
const math::Vector3d & Velocity() const
Get the velocity of the NavSat sensor in the ENU world frame.
a base sensor class
Definition: gz/sensors/Sensor.hh:60
