Gazebo Sensors
gz/sensors/Noise.hh
16 */
17
18 #ifndef GZ_SENSORS_NOISE_HH_
19 #define GZ_SENSORS_NOISE_HH_
20
21 #include <functional>
22 #include <string>
23 #include <vector>
24
25 #include <gz/sensors/config.hh>
27 #include <gz/sensors/Export.hh>
28
29 #include <sdf/sdf.hh>
30
31 namespace ignition
32 {
33  namespace sensors
34  {
35  // Inline bracket to help doxygen filtering.
36  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
37  // Forward declarations
38  class NoisePrivate;
39
42  class IGNITION_SENSORS_VISIBLE NoiseFactory
43  {
51  public: static NoisePtr NewNoiseModel(sdf::ElementPtr _sdf,
52  const std::string &_sensorType = "");
53
61  public: static NoisePtr NewNoiseModel(const sdf::Noise &_sdf,
62  const std::string &_sensorType = "");
63  };
64
66  enum class IGNITION_SENSORS_VISIBLE NoiseType : int
67  {
68  NONE = 0,
69  CUSTOM = 1,
70  GAUSSIAN = 2
71  };
72
75  class IGNITION_SENSORS_VISIBLE Noise
76  {
82  public: explicit Noise(NoiseType _type);
83
85  public: virtual ~Noise();
86
89  public: virtual void Load(const sdf::Noise &_sdf);
90
95  public: double Apply(double _in, double _dt = 0.0);
96
102  public: virtual double ApplyImpl(double _in, double _dt);
103
106  public: NoiseType Type() const;
107
112  public: virtual void SetCustomNoiseCallback(
113  std::function<double(double, double)> _cb);
114
117  public: virtual void Print(std::ostream &_out) const;
118
120  private: NoisePrivate *dataPtr = nullptr;
121  };
122  }
123  }
124 }
125 #endif
Use this noise manager for creating and loading noise models.
Definition: gz/sensors/Noise.hh:43
static NoisePtr NewNoiseModel(const sdf::Noise &_sdf, const std::string &_sensorType="")
Load a noise model based on the input sdf parameters and sensor type.
static NoisePtr NewNoiseModel(sdf::ElementPtr _sdf, const std::string &_sensorType="")
Noise models for sensor output signals.
Definition: gz/sensors/Noise.hh:76
Constructor. This should not be called directly unless creating an empty noise model....
virtual ~Noise()
Accessor for NoiseType.
Load noise parameters from sdf.
Apply noise to input data value. This gets overriden by derived classes, and called by Apply.
virtual void SetCustomNoiseCallback(std::function< double(double, double)> _cb)
Register a custom noise callback.
double Apply(double _in, double _dt=0.0)
Output information about the noise model.
Forward declarations and typedefs for sensors.
NoiseType
Which noise types we support.
Definition: gz/sensors/Noise.hh:67
