Gazebo Sensors
AirSpeedSensor Class Reference
AirSpeed Sensor Class. More...
#include <AirSpeedSensor.hh>
 AirSpeedSensor ()
 constructor More...
virtual ~AirSpeedSensor ()
 destructor More...
virtual bool Init () override
void SetVelocity (const gz::math::Vector3d &_vel)
 Update the velocity of the sensor. More...
 Update the sensor. More...
gz::math::Vector3d Velocity () const
 Get the current velocity. More...
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
double UpdateRate () const
 Sensor ()
 constructor More...
A sensor that reports air speed through differential pressure readings.
◆ AirSpeedSensor()
constructor
◆ ~AirSpeedSensor()
virtual ~AirSpeedSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetVelocity()
void SetVelocity ( const gz::math::Vector3d &  _vel)
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
virtual bool Update
SetUpdateRate()
◆ Update() [3/3]
bool Update
Update the sensor.
Remarks
◆ Velocity()
gz::math::Vector3d Velocity ( ) const
Current velocity of the sensor.
