Gazebo Sensors
gz::sensors Namespace Reference
Sensors namespace. More...
 GZ_SENSORS_VERSION_NAMESPACE
class  AirPressureSensor
class  AirSpeedSensor
 AirSpeed Sensor Class. More...
class  AltimeterSensor
class  BoundingBoxCameraSensor
 BoundingBox camera sensor class. More...
class  BrownDistortionModel
 Brown Distortion Model class. More...
class  CameraSensor
 Camera Sensor Class. More...
class  DepthCameraSensor
class  Distortion
 Distortion models for sensor output signals. More...
class  DistortionFactory
 Use this distortion manager for creating and loading distortion models. More...
class  DopplerVelocityLog
 Doppler velocity log (DVL) sensor, built as a custom rendering sensor to leverage GPU shaders for speed. More...
struct  EntityKinematicState
 Kinematic state for an entity in the world. More...
struct  EnvironmentalData
 Environment data across time and space. This is useful to introduce physical quantities that may be of interest even if not modelled in simulation. More...
class  ForceTorqueSensor
 Force Torque Sensor Class. More...
class  GaussianNoiseModel
 Gaussian noise class. More...
class  GpuLidarSensor
 GpuLidar Sensor Class. More...
class  ImageBrownDistortionModel
 Distortion Model class for image sensors. More...
class  ImageDistortionFactory
class  ImageGaussianNoiseModel
 Gaussian noise class for image sensors. More...
class  ImageNoiseFactory
class  ImuSensor
 Imu Sensor Class. More...
class  Lidar
class  LogicalCameraSensor
class  MagnetometerSensor
class  Manager
class  NavSatSensor
 NavSat Sensor Class. More...
class  Noise
class  NoiseFactory
class  RenderingEvents
class  RenderingSensor
class  RgbdCameraSensor
class  SegmentationCameraSensor
 Segmentation camera sensor class. More...
class  Sensor
 a base sensor class More...
class  SensorFactory
class  ThermalCameraSensor
class  WideAngleCameraSensor
 Wide Angle camera sensor class. More...
struct  WorldState
 Kinematic state for all entities in the world. More...
typedef std::shared_ptr< BrownDistortionModel > BrownDistortionModelPtr
typedef std::vector< CameraSensorPtr > CameraSensor_V
typedef std::shared_ptr< CameraSensor > CameraSensorPtr
typedef std::shared_ptr< Distortion > DistortionPtr
typedef std::shared_ptr< GaussianNoiseModel > GaussianNoiseModelPtr
typedef std::vector< GpuLidarSensorPtr > GpuLidarSensor_V
typedef std::shared_ptr< GpuLidarSensor > GpuLidarSensorPtr
typedef std::shared_ptr< ImageBrownDistortionModel > ImageBrownDistortionModelPtr
typedef std::shared_ptr< ImageGaussianNoiseModel > ImageGaussianNoiseModelPtr
 Shared pointer to Noise. More...
typedef std::shared_ptr< Noise > NoisePtr
typedef std::vector< SensorPtr > Sensor_V
using SensorId = std::size_t
 A string used to identify a sensor. More...
typedef std::shared_ptr< Sensor > SensorPtr
using WorldKinematicState = std::unordered_map< uint64_t, EntityKinematicState >
Enumerations
enum class  DistortionType : int { NONE = 0 , CUSTOM = 1 , BROWN = 2 }
 Which distortion types we support. More...
enum class  NoiseType : int { NONE = 0 , CUSTOM = 1 , GAUSSIAN = 2 }
 Which noise types we support. More...
enum  SensorCategory { IMAGE = 0 , RAY = 1 , OTHER = 2 , CATEGORY_COUNT = 3 }
 SensorCategory is used to categorize sensors. This is used to put sensors into different threads. More...
enum  SensorDistortionType { SENSOR_DISTORTION_TYPE_BEGIN = 0 , NO_DISTORTION = SENSOR_DISTORTION_TYPE_BEGIN , CAMERA_DISTORTION = 1 , SENSOR_DISTORTION_TYPE_END }
enum  SensorNoiseType {
  SENSOR_NOISE_TYPE_BEGIN = 0 , NO_NOISE = SENSOR_NOISE_TYPE_BEGIN , CAMERA_NOISE = 1 , MAGNETOMETER_X_NOISE_TESLA = 2 ,
  MAGNETOMETER_Y_NOISE_TESLA = 3 , MAGNETOMETER_Z_NOISE_TESLA = 4 , ALTIMETER_VERTICAL_POSITION_NOISE_METERS = 5 , ALTIMETER_VERTICAL_VELOCITY_NOISE_METERS_PER_S = 6 ,
  AIR_PRESSURE_NOISE_PASCALS = 7 , ACCELEROMETER_X_NOISE_M_S_S = 8 , ACCELEROMETER_Y_NOISE_M_S_S = 9 , ACCELEROMETER_Z_NOISE_M_S_S = 10 ,
  GYROSCOPE_X_NOISE_RAD_S = 11 , GYROSCOPE_Y_NOISE_RAD_S = 12 , GYROSCOPE_Z_NOISE_RAD_S = 13 , LIDAR_NOISE = 14 ,
  FORCE_X_NOISE_N = 15 , FORCE_Y_NOISE_N = 16 , FORCE_Z_NOISE_N = 17 , TORQUE_X_NOISE_N_M = 18 ,
  TORQUE_Y_NOISE_N_M = 19 , TORQUE_Z_NOISE_N_M = 20 , NAVSAT_HORIZONTAL_POSITION_NOISE = 21 , NAVSAT_VERTICAL_POSITION_NOISE = 22 ,
  NAVSAT_HORIZONTAL_VELOCITY_NOISE = 23 , NAVSAT_VERTICAL_VELOCITY_NOISE = 24 , AIR_SPEED_NOISE_PASCALS = 25 , SENSOR_NOISE_TYPE_END
enum class  WorldFrameEnumType {
  NONE = 0 , ENU = 1 , NED = 2 , NWU = 3 ,
  CUSTOM = 4
 Inline bracket to help doxygen filtering. More...
Functions
std::string customType (const sdf::Sensor &_sdf)
 Get the name of a sensor's custom type from SDF. More...
std::string customType (sdf::ElementPtr _sdf)
Variables
const SensorId NO_SENSOR = 0
Sensors namespace.
Typedef Documentation
◆ BrownDistortionModelPtr
◆ CameraSensor_V
◆ CameraSensorPtr
◆ DistortionPtr
◆ GaussianNoiseModelPtr
◆ GpuLidarSensor_V
◆ GpuLidarSensorPtr
◆ ImageBrownDistortionModelPtr
◆ ImageGaussianNoiseModelPtr
◆ NoisePtr
◆ Sensor_V
◆ SensorId
◆ SensorPtr
◆ WorldKinematicState
◆ DistortionType
enum DistortionType : int
strong
Enumerator
NONE
CUSTOM
BROWN
◆ NoiseType
enum NoiseType : int
strong
Enumerator
NONE
CUSTOM
GAUSSIAN
◆ SensorCategory
Enumerator
Image based sensor class. This type requires the rendering engine.
RAY
Ray based sensor class.
OTHER
A type of sensor is not a RAY or IMAGE sensor.
CATEGORY_COUNT
Number of Sensor Categories.
◆ SensorDistortionType
Enumerator
NO_DISTORTION
Noise streams for the Camera sensor.
CameraSensor
CAMERA_DISTORTION
CameraSensor
◆ SensorNoiseType
Enumerator
NO_NOISE
CameraSensor
CAMERA_NOISE
CameraSensor
Magnetometer body-frame X axis noise in Tesla.
MagnetometerSensor
Magnetometer body-frame Y axis noise in Tesla.
MagnetometerSensor
Magnetometer body-frame Z axis noise in Tesla.
MagnetometerSensor
Vertical noise stream for the altimeter sensor.
AltimeterSensor
Velocity noise streams for the altimeter sensor.
AltimeterSensor
Air Pressure noise streams for the air pressure sensor.
AirPressureSensor
Accelerometer body-frame X axis noise in m/s^2.
ImuSensor
Accelerometer body-frame Y axis noise in m/s^2.
ImuSensor
Accelerometer body-frame Z axis noise in m/s^2.
ImuSensor
Gyroscope body-frame X axis noise in m/s^2.
ImuSensor
ImuSensor
ImuSensor
LIDAR_NOISE
Noise streams for the Lidar sensor.
Lidar
FORCE_X_NOISE_N
Force body-frame X axis noise in N.
ForceTorqueSensor
FORCE_Y_NOISE_N
Force body-frame Y axis noise in N.
ForceTorqueSensor
FORCE_Z_NOISE_N
Force body-frame Z axis noise in N.
ForceTorqueSensor
TORQUE_X_NOISE_N_M
Torque body-frame X axis noise in Nm.
ForceTorqueSensor
TORQUE_Y_NOISE_N_M
Torque body-frame Y axis noise in Nm.
ForceTorqueSensor
TORQUE_Z_NOISE_N_M
Torque body-frame Z axis noise in Nm.
ForceTorqueSensor
Noise streams for the NavSat position sensor.
NavSat
NavSat
Noise streams for the NavSat velocity sensor.
NavSat
NavSat
Air speed noise streams for the air speed sensor.
AirSpeedSensor
◆ WorldFrameEnumType
enum WorldFrameEnumType
strong
Reference frames enum
Enumerator
NONE
NONE : To be used only when <localization> reference orientation tag is empty.
ENU
ENU (East-North-Up): x - East, y - North, z - Up.
NED
NED (North-East-Down): x - North, y - East, z - Down.
NWU
NWU (North-West-Up): x - North, y - West, z - Up.
CUSTOM
CUSTOM : The frame is described using custom_rpy tag.
Function Documentation
◆ customType() [1/2]
std::string gz::sensors::customType ( const sdf::Sensor &  _sdf)
Given an SDF tag as follows:
<sensor name="sensor_name" type="custom" gz:type="sensor_type">
This function returns sensor_type.
It will return an empty string if the element is malformed. For example, if it misses the gz:type attribute or is not of type="custom".
[in]_sdfSensor SDF object.
_sensorType Name of sensor type.
◆ customType() [2/2]
std::string gz::sensors::customType ( sdf::ElementPtr  _sdf)
Variable Documentation
◆ NO_SENSOR
