Gazebo Sensors
AltimeterSensor Class Reference
#include <AltimeterSensor.hh>
 AltimeterSensor ()
 constructor More...
virtual ~AltimeterSensor ()
 destructor More...
virtual bool Init () override
void SetPosition (double _pos)
 Set the current z position of the altimeter. More...
void SetVerticalReference (double _reference)
 Set the vertical reference position of the altimeter. More...
void SetVerticalVelocity (double _vel)
 Set the vertical velocity of the altimeter. More...
 Update the sensor. More...
double VerticalPosition () const
 Get the vertical position of the altimeter relative to the reference position. More...
double VerticalReference () const
 Get the vertical reference position of the altimeter. More...
double VerticalVelocity () const
 Get the vertical velocity of the altimeter. More...
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
double UpdateRate () const
 Sensor ()
 constructor More...
An altimeter sensor that reports vertical position and velocity readings over gz transport
◆ AltimeterSensor()
constructor
◆ ~AltimeterSensor()
virtual ~AltimeterSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetPosition()
void SetPosition ( double  _pos)
[in]_posZ position in meters
◆ SetVerticalReference()
void SetVerticalReference ( double  _reference)
[in]_referenceVerical reference position in meters
◆ SetVerticalVelocity()
void SetVerticalVelocity ( double  _vel)
[in]_velVertical velocity in meters per second
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
virtual bool Update
SetUpdateRate()
◆ Update() [3/3]
bool Update
Update the sensor.
Remarks
◆ VerticalPosition()
double VerticalPosition ( ) const
Vertical position relative to referene position
◆ VerticalReference()
double VerticalReference ( ) const
◆ VerticalVelocity()
double VerticalVelocity ( ) const
