Gazebo Sensors
SensorFactory Class Reference
#include <SensorFactory.hh>
 SensorFactory ()
 ~SensorFactory ()
template<typename SensorType >
std::unique_ptr< SensorType > CreateSensor (const sdf::Sensor &_sdf)
 Create a sensor from a SDF DOM object with a known sensor type. More...
std::unique_ptr< SensorType > CreateSensor (sdf::ElementPtr _sdf)
 Create a sensor from an SDF element with a known sensor type. More...
◆ SensorFactory()
◆ ~SensorFactory()
◆ CreateSensor() [1/2]
std::unique_ptr<SensorType> CreateSensor ( const sdf::Sensor &  _sdf)
inline
This creates sensors by looking at the given SDF DOM object. Sensors created with this API offer an gz-transport interface. If you need a direct C++ interface to the data, you must get the sensor pointer and cast to the correct type.
Sensor()
[in]_sdfSDF Sensor DOM object.
Template Parameters
SensorTypeSensor type
A pointer to the created sensor. Null returned on error.
References std::endl().
◆ CreateSensor() [2/2]
std::unique_ptr<SensorType> CreateSensor ( sdf::ElementPtr  _sdf)
inline
Sensor()
[in]_sdfpointer to the sdf element
Template Parameters
