Gazebo Sensors
Environment data across time and space. This is useful to introduce physical quantities that may be of interest even if not modelled in simulation. More...
#include <EnvironmentalData.hh>
Public Types
using FrameT = common::DataFrame< std::string, T >
using ReferenceT = math::SphericalCoordinates::CoordinateType
enum class  ReferenceUnits { RADIANS = 0 , DEGREES }
 Reference units. More...
using T = math::InMemoryTimeVaryingVolumetricGrid< double >
static std::shared_ptr< EnvironmentalDataMakeShared (FrameT _frame, ReferenceT _reference, ReferenceUnits _units=ReferenceUnits::RADIANS, bool _ignoreTimeStep=false)
 Instantiate environmental data. More...
Public Attributes
FrameT frame
 Environmental data frame. More...
ReferenceT reference
 Spatial reference for data coordinates. More...
bool staticTime
 Use time axis or not. More...
ReferenceUnits units
 The units to be used (only for spherical coordinates) More...
Member Typedef Documentation
◆ FrameT
using FrameT = common::DataFrame<std::string, T>
◆ ReferenceT
◆ T
using T = math::InMemoryTimeVaryingVolumetricGrid<double>
◆ ReferenceUnits
enum ReferenceUnits
strong
Reference units.
Enumerator
RADIANS
DEGREES
◆ MakeShared()
static std::shared_ptr<EnvironmentalData> MakeShared ( FrameT  _frame,
ReferenceUnits  _units = ReferenceUnits::RADIANS,
bool  _ignoreTimeStep = false
static
An std::make_shared equivalent that ensures dynamically loaded call sites use a template instantiation that is guaranteed to outlive them.
◆ frame
FrameT frame
◆ reference
◆ staticTime
bool staticTime
◆ units
