Gazebo Sensors
WideAngleCameraSensor Class Reference
Wide Angle camera sensor class. More...
#include <WideAngleCameraSensor.hh>
 WideAngleCameraSensor ()
 constructor More...
virtual ~WideAngleCameraSensor ()
 destructor More...
common::ConnectionPtr ConnectImageCallback (std::function< void(const msgs::Image &)> _callback)
 Get image height. More...
 Get image width. More...
virtual bool Init () override
void OnNewWideAngleFrame (const unsigned char *_data, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Image data callback used to get the data from the sensor. More...
rendering::CameraPtr RenderingCamera () const override
virtual rendering::WideAngleCameraPtr WideAngleCamera () const
 Get a pointer to the rendering wide angle camera. More...
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
 Check if there are any image subscribers. More...
 Check if there are any info subscribers. More...
 Get the camera optical frame. More...
 Set the camera info topic. More...
 Update the sensor. More...
 Set camera lens intrinsics and projection based on values from SDF. If the camera SDF does not contain intrinsic or projection parameters, the camera will not be updated. Instead, the camera SDF will be updated with intrinsic and projection values computed manually from current camera intrinsic properties. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates wide angle camera image from a Gazebo Rendering scene. The scene must be created in advance and given to Manager::Init() It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ WideAngleCameraSensor()
constructor
◆ ~WideAngleCameraSensor()
virtual ~WideAngleCameraSensor ( )
destructor
◆ ConnectImageCallback()
common::ConnectionPtr ConnectImageCallback ( std::function< void(const msgs::Image &)>  _callback)
Remarks
◆ HasConnections()
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewWideAngleFrame()
void OnNewWideAngleFrame ( const unsigned char *  _data,
const std::string &  _format
[in]_datapointer to the data from the sensor
[in]_widthwidth of the image
[in]_heightheight of the image
[in]_channelsbytes used for the image data
[in]_formatstring with the format
◆ RenderingCamera()
rendering::CameraPtr RenderingCamera ( ) const
Camera in Gazebo Rendering.
◆ SetScene()
[in]_nowThe current time
◆ WideAngleCamera()
virtual rendering::WideAngleCameraPtr WideAngleCamera ( ) const
Wide angle camera
