Gazebo Sensors
RgbdCameraSensor Class Reference
#include <RgbdCameraSensor.hh>
 RgbdCameraSensor ()
 constructor More...
virtual ~RgbdCameraSensor ()
 destructor More...
virtual bool HasColorConnections () const
 Check if there are color subscribers. More...
virtual bool HasDepthConnections () const
 Check if there are depth subscribers. More...
virtual bool HasPointConnections () const
 Check if there are point cloud subscribers. More...
 Get image height. More...
 Get image width. More...
virtual bool Init () override
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
 Check if there are any image subscribers. More...
 Check if there are any info subscribers. More...
 Get the camera optical frame. More...
 Set the camera info topic. More...
 Update the sensor. More...
 Set camera lens intrinsics and projection based on values from SDF. If the camera SDF does not contain intrinsic or projection parameters, the camera will not be updated. Instead, the camera SDF will be updated with intrinsic and projection values computed manually from current camera intrinsic properties. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates a few types of sensor data from a Gazebo Rendering scene:
  • RGB image (same as CameraSensor)
  • Depth image (same as DepthCamera)
  • (future / todo) Color point cloud The scene must be created in advance and given to Manager::Init(). It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ RgbdCameraSensor()
constructor
◆ ~RgbdCameraSensor()
virtual ~RgbdCameraSensor ( )
destructor
◆ HasColorConnections()
virtual bool HasColorConnections ( ) const
◆ HasConnections()
◆ HasDepthConnections()
virtual bool HasDepthConnections ( ) const
◆ HasPointConnections()
virtual bool HasPointConnections ( ) const
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetScene()
[in]_nowThe current time
true if the update was successful
