Gazebo Sensors
MagnetometerSensor Class Reference
#include <MagnetometerSensor.hh>
 MagnetometerSensor ()
 constructor More...
virtual ~MagnetometerSensor ()
 destructor More...
virtual bool Init () override
math::Vector3d MagneticField () const
 Get the magnetic field vector in body frame. More...
void SetWorldMagneticField (const math::Vector3d &_field)
 Set the magnetic field vector in world frame. More...
 Set the world pose of the sensor. More...
 Update the sensor. More...
math::Vector3d WorldMagneticField () const
 Get the magnetic field vector in world frame. More...
 Get the world pose of the sensor. More...
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
double UpdateRate () const
 Sensor ()
 constructor More...
A magnetometer reports the magnetic field vector
◆ MagnetometerSensor()
constructor
◆ ~MagnetometerSensor()
virtual ~MagnetometerSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ MagneticField()
math::Vector3d MagneticField ( ) const
Magnetic field vector in body frame
◆ SetWorldMagneticField()
void SetWorldMagneticField ( const math::Vector3d &  _field)
[in]_fieldMagnetic field vector in world frame.
◆ SetWorldPose()
[in]_posePose in world frame
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
virtual bool Update
SetUpdateRate()
◆ Update() [3/3]
bool Update
Update the sensor.
Remarks
◆ WorldMagneticField()
math::Vector3d WorldMagneticField ( ) const
◆ WorldPose()
Pose in world frame.
