Gazebo Sensors
GpuLidarSensor Class Reference
GpuLidar Sensor Class. More...
#include <GpuLidarSensor.hh>
 GpuLidarSensor ()
 constructor More...
virtual ~GpuLidarSensor ()
 destructor More...
virtual gz::common::ConnectionPtr ConnectNewLidarFrame (std::function< void(const float *_scan, unsigned int _width, unsigned int _heighti, unsigned int _channels, const std::string &)> _subscriber) override
 Connect function pointer to internal GpuRays callback. More...
virtual bool CreateLidar () override
 Create Lidar sensor. More...
gz::rendering::GpuRaysPtr GpuRays () const
 Get Gpu Rays object used in the sensor. More...
gz::math::Angle HFOV () const
 Get the horizontal field of view of the laser sensor. More...
virtual bool Init () override
bool IsHorizontal () const
 Load sensor sata from SDF. More...
double RayCountRatio () const
 Return the ratio of horizontal ray count to vertical ray count. More...
void RemoveGpuRays (gz::rendering::ScenePtr _scene)
 Remove sensor from scene. More...
void SetScene (gz::rendering::ScenePtr _scene) override
 Makes possible to change sensor scene. More...
gz::math::Angle VFOV () const
- Public Member Functions inherited from Lidar
 Lidar ()
 constructor More...
virtual ~Lidar ()
 destructor More...
gz::math::Angle AngleMax () const
 Get the maximum angle. More...
gz::math::Angle AngleMin () const
 Get the minimum angle. More...
double AngleResolution () const
 Get radians between each range. More...
void ApplyNoise ()
 Apply noise to the laser buffer, if noise has been configured. This should be called before PublishLidarScan if you want the scan data to contain noise. More...
int Fiducial (const unsigned int _index) const
 Get detected fiducial value for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More...
double HorzFOV () const
virtual bool IsActive () const
virtual bool PublishLidarScan (const std::chrono::steady_clock::duration &_now)
 Publish LaserScan message. More...
double Range (const int _index) const
 Get detected range for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More...
unsigned int RangeCount () const
 Get the range count. More...
double RangeCountRatio () const
 Return the ratio of horizontal range count to vertical range count. More...
double RangeMax () const
 Get the maximum range. More...
double RangeMin () const
 Get the minimum range. More...
double RangeResolution () const
 Get the range resolution If RangeResolution is 1, the number of simulated rays is equal to the number of returned range readings. If it's less than 1, fewer simulated rays than actual returned range readings are used, the results are interpolated from two nearest neighbors, and vice versa. More...
void Ranges (std::vector< double > &_ranges) const
 Get all the ranges. More...
unsigned int RayCount () const
 Get the ray count. More...
double Retro (const int _index) const
 Get detected retro (intensity) value for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More...
void SetAngleMax (const double _angle)
 Set the scan maximum angle. More...
void SetAngleMin (const double _angle)
 Set the scan minimum angle. More...
void SetParent (const std::string &_parent) override
void SetVerticalAngleMax (const double _angle)
 Set the vertical scan line top angle. More...
void SetVerticalAngleMin (const double _angle)
 Set the vertical scan bottom angle. More...
double VertFOV () const
gz::math::Angle VerticalAngleMax () const
 Get the vertical scan line top angle. More...
gz::math::Angle VerticalAngleMin () const
 Get the vertical scan bottom angle. More...
double VerticalAngleResolution () const
 Get the vertical angle in radians between each range. More...
unsigned int VerticalRangeCount () const
 Get the vertical scan line count. More...
unsigned int VerticalRayCount () const
uint32_t VisibilityMask () const
 Get the visibility mask. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsTriggered () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
- Public Attributes inherited from Lidar
bool initialized = false
 true if Load() has been called and was successful More...
float * laserBuffer = nullptr
 Raw buffer of laser data. More...
std::mutex lidarMutex
 Just a mutex for thread safety. More...
- Protected Member Functions inherited from Lidar
virtual void Fini ()
 Finalize the ray. More...
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates laser scans using the GPU. It's measures the range from the origin of the center to points on the visual geometry in the scene.
It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ GpuLidarSensor()
constructor
◆ ~GpuLidarSensor()
virtual ~GpuLidarSensor ( )
destructor
◆ ConnectNewLidarFrame()
virtual gz::common::ConnectionPtr ConnectNewLidarFrame ( std::function< void(const float *_scan, unsigned int _width, unsigned int _heighti, unsigned int _channels, const std::string &)>  _subscriber)
gz::common::Connection pointer
Reimplemented from Lidar.
◆ CreateLidar()
virtual bool CreateLidar ( )
◆ GpuRays()
gz::rendering::GpuRaysPtr GpuRays ( ) const
Pointer to gz::rendering::GpuRays
◆ HasConnections()
◆ HFOV()
gz::math::Angle HFOV ( ) const
The horizontal field of view of the laser sensor.
virtual bool Init ( )
True on success
◆ IsHorizontal()
bool IsHorizontal ( ) const
◆ Load() [1/2]
◆ Load() [2/2]
[in]_sdfSDF used
True on success
◆ RayCountRatio()
double RayCountRatio ( ) const
A ray count is the number of simulated rays. Whereas a range count is the total number of data points returned. When range count != ray count, then values are interpolated between rays.
◆ RemoveGpuRays()
void RemoveGpuRays ( gz::rendering::ScenePtr  _scene)
[in]_sceneused with the sensor
◆ SetScene()
void SetScene ( gz::rendering::ScenePtr  _scene)
[in]_nowThe current time
◆ VFOV()
gz::math::Angle VFOV ( ) const
Vertical field of view.
