Gazebo Sensors
DopplerVelocityLog Class Reference
Doppler velocity log (DVL) sensor, built as a custom rendering sensor to leverage GPU shaders for speed. More...
#include <DopplerVelocityLog.hh>
 DopplerVelocityLog ()
 ~DopplerVelocityLog ()
 Inherits documentation from parent class. More...
virtual void PostUpdate (const std::chrono::steady_clock::duration &_now)
 Perform any sensor updates after the rendering pass. More...
std::vector< gz::rendering::SensorPtr > RenderingSensors () const
 Yield rendering sensors that underpin the implementation. More...
void SetEntity (uint64_t entity)
 Set this sensor's entity ID (for world state lookup). More...
void SetEnvironmentalData (const EnvironmentalData &_data)
 Set environmental _data to support DVL water-tracking. More...
void SetScene (gz::rendering::ScenePtr _scene) override
void SetWorldState (const WorldState &_state)
 Set world _state to support DVL water and bottom-tracking. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
virtual bool Init ()
 Initialize values in the sensor This will set the next update time to zero. This is particularly useful if simulation time has jumped backward, for example during a seek backward in a log file. More...
bool IsActive () const
bool IsTriggered () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
By default, this sensor uses an x-forward, y-left, z-up coordinate frame to report all measurements. All acoustic beams' lobes are expected to face downwards.
/// <sensor type="custom" gz:type="dvl">
///   <gz:dvl>
///     <arrangement degrees="true">
///       <beam id="1">
///         <aperture></aperture>
///         <rotation></rotation>
///         <tilt></tilt>
///       </beam>
///     </arrangement>
///     <tracking>
///       <bottom_mode>
///         <when></when>
///         <noise type="gaussian">
///           <stddev></stddev>
///         </noise>
///         <visualize></visualize>
///       </bottom_mode>
///       <water_mass_mode>
///         <when></when>
///         <water_velocity>
///           <x></x>
///           <y></y>
///           <z></z>
///         </water_velocity>
///         <boundaries>
///           <near>20.</near>
///           <far>60.</far>
///         </boundaries>
///         <bins>10</bins>
///         </noise>
///       </water_mass_mode>
///     <minimum_range></minimum_range>
///     <maximum_range></maximum_range>
///     <resolution></resolution>
///     <reference_frame></reference_frame>
///   </gz:dvl>
/// </sensor>
- `<arrangement>` describes the arrangement of acoustic beams
in the DVL sensor frame. It may include a `degrees` attribute
to signal use of degrees instead of radians for all angles
within, defaulting to radians if left unspecified.
- `<arrangement><beam>` describes one acoustic beam in the
arrangement. May include an `id` attribute, defaulting to the
last specified id plus 1 if left unspecified (or 0 if it's the
first).
- `<arrangement><beam><aperture>` sets the aperture angle for
the acoustic beam's main lobe (modelled as a cone). Defaults
to 90 degrees if left unspecified.
- `<arrangement><beam><rotation>` sets the rotation angle of
the acoustic beam's symmetry axis about the sensor frame z
axis. Defaults to 0 degrees if left unspecified.
- `<arrangement><beam><tilt>` sets the inclination angle of
the acoustic beam's symmetry axis w.r.t. the sensor frame -z
axis (ie. rotation about the -y axis). Defaults to 0 degrees
- `<arrangement><visualize>` enables visual aids to evaluate
acoustic beam arrangements. Beam lobes' are rendered and adjusted
in size to match range measurements.
- `<tracking>` configures velocity tracking modes for the DVL.
- `<tracking><bottom_mode>` configures the bottom tracking mode.
- `<tracking><bottom_mode><when>` enables (or disables) the bottom
tracking mode. Supported values are 'never', to disable it completely
(as if no `<bottom_mode>` configuration had been specified), 'always'
to enable it at all times, and 'best' to track at all times but only
publish estimates when it performs best among all configured modes.
Defaults to 'always' if left unspecified.
- `<tracking><bottom_mode><noise>` sets the noise model for velocity
estimates. Only 'gaussian' noise is currently supported. Defaults to
none if left unspecified.
- `<tracking><bottom_mode><visualize>` enables visual aids to validate
bottom tracking. Acoustic beam reflection paths are depicted, where
the color scales linearly in hue with measured speed and low opacity
sections depict range uncertainty (+/- 2 standard deviations).
- `<tracking><water_mass_mode>` configures the water-mass tracking
mode.
- `<tracking><water_mass_mode><when>` enables (or disables) the
water-mass tracking mode. Supported values are 'never', to disable it
completely (as if no `<water_mass_mode>` configuration had been
specified), 'always' to enable it at all times, and 'best' to track at
all times but only publish estimates when it performs best among all
configured modes. Defaults to 'always' if left unspecified.
- `<tracking><water_mass_mode><water_velocity>` set the variables in
world environmental data to be used to sample water velocity w.r.t.
the world frame in each axis. At least one axis must be specified.
- `<tracking><water_mass_mode><water_velocity><x>` set the variable
in world environmental data to be used to sample water velocity w.r.t.
the world frame along the x-axis (that is, towards east). Defaults to
none (and thus zero water velocity in this axis) if left unspecified.
- `<tracking><water_mass_mode><water_velocity><y>` set the variable in
world environmental data to be used to sample water velocity w.r.t. the
world frame along the y-axis (that is, towards north). Defaults to none
- `<tracking><water_mass_mode><water_velocity><z>` set the variable in
world frame along the z-axis (that is, upwards). Defaults to none (and
- `<tracking><water_mass_mode><boundaries>` sets water-mass layer
boundaries. These boundaries are planar at given z-offsets in the
sensor frame.
- `<tracking><water_mass_mode><boundaries><near>` sets the water-mass
layer boundary that is the closest to the sensor.
- `<tracking><water_mass_mode><boundaries><far>` sets the water-mass
layer boundary that is the farthest to the sensor.
- `<tracking><water_mass_mode><bins>` sets the number of bins to use
for water-mass velocity sampling. Each bin is a slab of water between
boundaries.
- `<tracking><water_mass_mode><noise>` sets the noise model for
velocity estimates. Only 'gaussian' noise is currently supported.
Defaults to none if left unspecified.
- `<tracking><water_mass_mode><visualize>` enables visual aids to
validate bottom tracking. Acoustic beam reflection paths are depicted,
where the color scales linearly in hue with measured speed and low
opacity sections depict range uncertainty (+/- 2 standard deviations).
- `<type>` sets the sensor type, either 'piston' or 'phased_array'.
Defaults to unspecified.
- `<resolution>` sets the resolution of the beam for bottom
tracking at a 1 m distance. Defaults to 1 cm if left unspecified.
- `<minimum_range>` sets a lower bound for range measurements.
- `<maximum_range>` sets an upper bound for range measurements.
Defaults to 100 m if left unspecified.
- `<reference_frame>` sets a transform from the sensor frame to the
reference frame in which all measurements are reported. Defaults to
the identity transform.
Note the tethys::DopplerVelocityLogSystem plugin must be
loaded for these custom sensors to be picked up and setup.
◆ DopplerVelocityLog()
◆ ~DopplerVelocityLog()
◆ HasConnections()
Reimplemented from Sensor.
◆ Load() [1/2]
◆ Load() [2/2]
◆ PostUpdate()
virtual void PostUpdate ( const std::chrono::steady_clock::duration &  _now)
◆ RenderingSensors()
std::vector<gz::rendering::SensorPtr> RenderingSensors ( ) const
◆ SetEntity()
void SetEntity ( uint64_t  entity)
◆ SetEnvironmentalData()
void SetEnvironmentalData ( const EnvironmentalData &  _data)
◆ SetScene()
void SetScene ( gz::rendering::ScenePtr  _scene)
◆ SetWorldState()
void SetWorldState ( const WorldState &  _state)
Implements Sensor.
