EnvironmentalData Struct Reference
Environment data across time and space. This is useful to introduce physical quantities that may be of interest even if not modelled in simulation. More...
#include <EnvironmentalData.hh>
Public Types | |
| using | FrameT = common::DataFrame< std::string, T > |
| using | ReferenceT = math::SphericalCoordinates::CoordinateType |
| enum class | ReferenceUnits { RADIANS = 0 , DEGREES } |
| Reference units. More... | |
| using | T = math::InMemoryTimeVaryingVolumetricGrid< double > |
Static Public Member Functions | |
| static std::shared_ptr< EnvironmentalData > | MakeShared (FrameT _frame, ReferenceT _reference, ReferenceUnits _units=ReferenceUnits::RADIANS, bool _ignoreTimeStep=false) |
| Instantiate environmental data. | |
Public Attributes | |
| FrameT | frame |
| Environmental data frame. | |
| ReferenceT | reference |
| Spatial reference for data coordinates. | |
| bool | staticTime |
| Use time axis or not. | |
| ReferenceUnits | units |
| The units to be used (only for spherical coordinates) | |
Member Typedef Documentation
◆ FrameT
| using FrameT = common::DataFrame<std::string, T> |
◆ ReferenceT
| using ReferenceT = math::SphericalCoordinates::CoordinateType |
◆ T
| using T = math::InMemoryTimeVaryingVolumetricGrid<double> |
◆ ReferenceUnits
strong |
◆ MakeShared()
static |
An std::make_shared equivalent that ensures dynamically loaded call sites use a template instantiation that is guaranteed to outlive them.
◆ frame
| FrameT frame |
◆ reference
| ReferenceT reference |
◆ staticTime
| bool staticTime |
◆ units
| ReferenceUnits units |
