Events.hh File Reference
#include <sdf/Element.hh>
#include <sdf/Plugin.hh>
#include <gz/common/Event.hh>
#include "gz/sim/config.hh"
#include "gz/sim/Entity.hh"
namespace  gz
namespace  gz::sim
namespace  gz::sim::events
using LoadSdfPlugins = common::EventT< void(Entity, sdf::Plugins), struct LoadPluginsTag >
 Event used to load plugins for an entity into simulation. Pass in the entity which will own the plugins, and an SDF element for the entity, which may contain multiple <plugin> tags. Makre sure that you don't also connect to the LoadPlugins event.
using Pause = gz::common::EventT< void(bool), struct PauseTag >
 The pause event can be used to pause or unpause simulation. Emit a value of true to pause simulation, and emit a value of false to unpause simulation.
using Stop = gz::common::EventT< void(void), struct StopTag >
 The stop event can be used to terminate simulation. Emit this signal to terminate an active simulation.
