LookupWheelSlip.hh File Reference
#include <gz/sim/System.hh>
#include <memory>
class  LookupWheelSlip
 Lookup Wheel Slip system. This plugin dynamically adjusts the wheel slip and friction parameters based on the wheel's position on the region covered by the specified lookup image map (slip map) where slip and friction values are encoded in the image's RGB channels. This plugin needs to be used together with the WheelSlip system. LookupWheelSlip system params: More...
namespace  gz
namespace  gz::sim
namespace  gz::sim::systems
