Parameters.hh File Reference
#include <Eigen/Geometry>
#include <vector>
#include "gz/sim/config.hh"
struct  NoiseParameters
 Noise parameters used when computing frame data. These are all assumed to be gaussian. More...
struct  Rotor
 A struct that holds various properties of a rotor. More...
struct  VehicleParameters
 A struct that holds properties of the vehicle such as mass, inertia and rotor configuration. Gravity is also included even though it's not a parameter unique to the vehicle. More...
 ignition
 ignition::gazebo
 ignition::gazebo::systems
 ignition::gazebo::systems::multicopter_control
using RotorConfiguration = std::vector< Rotor >
 A collection of Rotor objects. More...
