SystemLoader Class Reference
Class for loading/unloading System plugins. More...
#include <ignition/gazebo/SystemLoader.hh>
 SystemLoader ()
 ~SystemLoader ()
void AddSystemPluginPath (const std::string &_path)
 Add path to search for plugins. More...
std::optional< SystemPluginPtr > LoadPlugin (const sdf::ElementPtr &_sdf)
 Load and instantiate system plugin from an SDF element. More...
std::optional< SystemPluginPtr > LoadPlugin (const std::string &_filename, const std::string &_name, const sdf::ElementPtr &_sdf)
 Load and instantiate system plugin from name/filename. More...
std::string PrettyStr () const
 Makes a printable string with info about systems. More...
◆ SystemLoader()
SystemLoader ( )
◆ ~SystemLoader()
◆ AddSystemPluginPath()
void AddSystemPluginPath ( const std::string &  _path)
[in]_pathNew path to be added.
◆ LoadPlugin() [1/2]
std::optional<SystemPluginPtr> LoadPlugin ( const sdf::ElementPtr &  _sdf)
[in]_sdfSDF Element describing plugin instance to be loaded.
Shared pointer to system instance or nullptr.
◆ LoadPlugin() [2/2]
std::optional<SystemPluginPtr> LoadPlugin ( const std::string &  _filename,
const std::string &  _name,
[in]_filenameShared library filename to load plugin from.
[in]_nameClass name to be instantiated.
◆ PrettyStr()
std::string PrettyStr ( ) const
A pretty string
