gz/sim/ServerConfig.hh
16 */
17 #ifndef GZ_GAZEBO_SERVERCONFIG_HH_
18 #define GZ_GAZEBO_SERVERCONFIG_HH_
20 #include <chrono>
21 #include <list>
22 #include <memory>
23 #include <optional> // NOLINT(*)
24 #include <string>
25 #include <vector>
26 #include <sdf/Element.hh>
27 #include <gz/sim/config.hh>
28 #include <gz/sim/Export.hh>
29
30 namespace ignition
31 {
32  namespace gazebo
33  {
34  // Inline bracket to help doxygen filtering.
35  inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
36  // Forward declarations.
37  class ServerConfigPrivate;
38
43  class IGNITION_GAZEBO_VISIBLE ServerConfig
44  {
45  class PluginInfoPrivate;
52  public: class IGNITION_GAZEBO_VISIBLE PluginInfo
53  {
55  public: PluginInfo();
56
58  public: ~PluginInfo();
59
71  public: PluginInfo(const std::string &_entityName,
72  const std::string &_entityType,
73  const std::string &_filename,
74  const std::string &_name,
75  const sdf::ElementPtr &_sdf);
76
79  public: PluginInfo(const PluginInfo &_info);
80
84  public: PluginInfo &operator=(const PluginInfo &_info);
85
90  public: const std::string &EntityName() const;
91
96  public: void SetEntityName(const std::string &_entityName);
97
102  public: const std::string &EntityType() const;
103
108  public: void SetEntityType(const std::string &_entityType);
109
112  public: const std::string &Filename() const;
113
118  public: void SetFilename(const std::string &_filename);
119
123  public: const std::string &Name() const;
124
128  public: void SetName(const std::string &_name);
129
132  public: const sdf::ElementPtr &Sdf() const;
133
136  public: void SetSdf(const sdf::ElementPtr &_sdf);
137
140  };
141
143  public: ServerConfig();
144
147  public: ServerConfig(const ServerConfig &_config);
148
150  public: ~ServerConfig();
151
158  public: bool SetSdfFile(const std::string &_file);
159
163  public: std::string SdfFile() const;
164
171  public: bool SetSdfString(const std::string &_sdfString);
172
176  public: std::string SdfString() const;
177
180  public: void SetUpdateRate(const double &_hz);
181
185  public: std::optional<double> UpdateRate() const;
186
189  public: bool UseLevels() const;
190
193  public: void SetUseLevels(const bool _levels);
194
199  public: bool UseDistributedSimulation() const;
200
207  public: void SetNetworkSecondaries(unsigned int _secondaries);
208
213  public: unsigned int NetworkSecondaries() const;
214
222  public: void SetNetworkRole(const std::string &_role);
223
229  public: std::string NetworkRole() const;
230
233  public: bool UseLogRecord() const;
234
237  public: void SetUseLogRecord(const bool _record);
238
241  public: const std::string LogRecordPath() const;
242
245  public: void SetLogRecordPath(const std::string &_recordPath);
246
250  public: bool LogIgnoreSdfPath() const;
251
257  public: void SetLogIgnoreSdfPath(bool _ignore);
258
261  public: void AddLogRecordTopic(const std::string &_topic);
262
265  public: void ClearLogRecordTopics();
266
270  public: const std::vector<std::string> &LogRecordTopics() const;
271
274  public: const std::string LogPlaybackPath() const;
275
278  public: void SetLogPlaybackPath(const std::string &_playbackPath);
279
282  public: bool LogRecordResources() const;
283
286  public: void SetLogRecordResources(bool _recordResources);
287
290  public: std::string LogRecordCompressPath() const;
291
294  public: void SetLogRecordCompressPath(const std::string &_path);
295
298  public: unsigned int Seed() const;
299
302  public: void SetSeed(unsigned int _seed);
303
307  public: std::optional<std::chrono::steady_clock::duration>
308  UpdatePeriod() const;
309
315  public: const std::string &ResourceCache() const;
316
322  public: void SetResourceCache(const std::string &_path);
323
326  public: const std::string &PhysicsEngine() const;
327
330  public: void SetPhysicsEngine(const std::string &_physicsEngine);
331
334  public: const std::string &RenderEngineServer() const;
335
338  public: const std::string &RenderEngineGui() const;
339
342  public: void SetRenderEngineServer(
343  const std::string &_renderEngineServer);
344
347  public: void SetRenderEngineGui(const std::string &_renderEngineGui);
348
352  public: void AddPlugin(const PluginInfo &_info);
353
356  public: void AddPlugins(const std::list<PluginInfo> &_plugins);
357
365  public: PluginInfo LogRecordPlugin() const;
366
370  public: PluginInfo LogPlaybackPlugin() const;
371
375  public: const std::list<PluginInfo> &Plugins() const;
376
380  public: ServerConfig &operator=(const ServerConfig &_cfg);
381
388  Timestamp() const;
389
391  private: std::unique_ptr<ServerConfigPrivate> dataPtr;
392  };
393
398  IGNITION_GAZEBO_VISIBLE
399  parsePluginsFromFile(const std::string &_fname);
400
405  IGNITION_GAZEBO_VISIBLE
406  parsePluginsFromString(const std::string &_str);
407
424  //
427  //
430  IGNITION_GAZEBO_VISIBLE
431  loadPluginInfo(bool _isPlayback = false);
432  }
433  }
434 }
435
436 #endif
Get the network role. See SetNetworkRole(const std::string &_role) for more information about distrib...
Get file path to compress log files to.
Set an SDF string to be used by the server.
Set whether to ignore the path specified in SDF. Path in SDF should be ignored if a record path is sp...
Configuration parameters for a Server. An instance of this object can be used to construct a Server w...
Definition: gz/sim/ServerConfig.hh:43
Set file path to compress log files to.
Add a topic to record.
Clear topics to record. This will remove all topics set using AddLogRecordTopic.
void AddPlugins(const std::list< PluginInfo > &_plugins)
Add multiple plugins to the simulation.
Set the type of the entity which should receive this plugin. The type is used in conjuction with Enti...
std::optional< std::chrono::steady_clock::duration > UpdatePeriod() const
Get the update period duration.
STL class.
Set the plugin XML elements associated with this plugin.
STL class.
const std::string & Filename() const
Get the plugin library filename.
Set whether the server is recording states.
const std::string & PhysicsEngine() const
Physics engine plugin library to load.
std::list< ServerConfig::PluginInfo > loadPluginInfo(bool _isPlayback=false)
Load plugin information, following ordering.
STL class.
Set the update rate in Hertz. Value <=0 are ignored.
const std::vector< std::string > & LogRecordTopics() const
Get the topics to record that were added using AddLogRecordTopic.
Get whether the server is using the level system.
Get path to place recorded states.
The given random seed.
const std::chrono::time_point< std::chrono::system_clock > & Timestamp() const
Get the timestamp of this ServerConfig. This is the system time when this ServerConfig was created....
Set the number of network secondary servers that the primary server should expect....
ServerConfig & operator=(const ServerConfig &_cfg)
Equal operator.
std::list< ServerConfig::PluginInfo > parsePluginsFromFile(const std::string &_fname)
Parse plugins from XML configuration file.
Set path to place recorded states.
Component< std::string, class NameTag > Name
This component holds an entity's name. The component has no concept of scoped names nor does it care ...
Definition: gz/sim/components/Name.hh:35
void SetRenderEngineServer(const std::string &_renderEngineServer)
Set the render engine server plugin library.
std::chrono::steady_clock::time_point Timestamp
Set the physics engine plugin library.
Generate PluginInfo for Log playback based on the internal state of this ServerConfig object:
const std::string & ResourceCache() const
Path to where simulation resources, such as models downloaded from fuel.ignitionrobotics....
Get the number of secondary servers that a primary server should expect.
Get the SDF file that has been set. An empty string will be returned if an SDF file has not been set.
Get path to recorded states to play back.
Set path to recorded states to play back.
std::list< ServerConfig::PluginInfo > parsePluginsFromString(const std::string &_str)
Parse plugins from XML configuration string.
Set whether meshes and material files are recorded.
Generate PluginInfo for Log recording based on the internal state of this ServerConfig object:
Set the render engine gui plugin library.
const std::string & RenderEngineGui() const
Render engine plugin library to load.
Set an SDF file to be used with the server.
Set the name of the interface within the plugin library to load.
Instruct simulation to attach a plugin to a specific entity when simulation starts.
PluginInfo & operator=(const PluginInfo &_info)
Equal operator.
Set the path to where simulation resources, such as models downloaded from fuel.ignitionrobotics....
const std::string & EntityType() const
Get the entity type which should receive this plugin. The type is used in conjuction with EntityName ...
Get whether meshes and material files are recorded.
Set the name of the entity which should receive this plugin. The name is used in conjuction with _ent...
const std::list< PluginInfo > & Plugins() const
Get all the plugins that should be loaded.
const std::string & RenderEngineServer() const
const std::string & EntityName() const
Get the name of the entity which should receive this plugin. The name is used in conjuction with _ent...
const sdf::ElementPtr & Sdf() const
Plugin XML elements associated with this plugin.
Set the random seed.
Get whether the server is recording states.
Get whether the server is using the distributed sim system.
Information about a plugin that should be loaded by the server.
Definition: gz/sim/ServerConfig.hh:52
Set the network role, which is one of [primary, secondary]. If primary is used, then make sure to als...
Get the SDF String that has been set. An empty string will be returned if an SDF string has not been ...
std::optional< double > UpdateRate() const
Get the update rate in Hertz.
Get whether to ignore the path specified in SDF.
const std::string & Name() const
Name of the interface within the plugin library to load.
