gz/sim/Util.hh File Reference
#include <gz/msgs/entity.pb.h>
#include <string>
#include <unordered_set>
#include <vector>
#include <gz/math/Pose3.hh>
#include "gz/sim/config.hh"
#include "gz/sim/Entity.hh"
#include "gz/sim/EntityComponentManager.hh"
#include "gz/sim/Export.hh"
#include "gz/sim/Types.hh"
 ignition
 ignition::gazebo
Functions
void addResourcePaths (const std::vector< std::string > &_paths={})
 Add resource paths based on latest environment variables. This will update the SDF and Ignition environment variables, and optionally add more paths to the list. More...
std::string asFullPath (const std::string &_uri, const std::string &_filePath)
 Combine a URI and a file path into a full path. If the URI is already a full path or contains a scheme, it won't be modified. If the URI is a relative path, the file path will be prepended. More...
template<class ComponentType >
bool enableComponent (EntityComponentManager &_ecm, Entity _entity, bool _enable=true)
 Helper function to "enable" a component (i.e. create it if it doesn't exist) or "disable" a component (i.e. remove it if it exists). More...
std::unordered_set< Entity > entitiesFromScopedName (const std::string &_scopedName, const EntityComponentManager &_ecm, Entity _relativeTo=kNullEntity, const std::string &_delim="::")
 Helper function to get an entity given its scoped name. The scope may start at any level by default. For example, in this hierarchy: More...
Entity entityFromMsg (const EntityComponentManager &_ecm, const msgs::Entity &_msg)
 Helper function to get an entity from an entity message. The returned entity is not guaranteed to exist. More...
ComponentTypeId entityTypeId (const Entity &_entity, const EntityComponentManager &_ecm)
 Generally, each entity will be of some specific high-level type, such as World, Sensor, Collision, etc, and one type only. The entity type is usually marked by having some component that represents that type, such as gz::sim::components::Visual. More...
std::string entityTypeStr (const Entity &_entity, const EntityComponentManager &_ecm)
 Generally, each entity will be of some specific high-level type, such as "world", "sensor", "collision", etc, and one type only. More...
std::string removeParentScope (const std::string &_name, const std::string &_delim)
 Helper function to remove a parent scope from a given name. This removes the first name found before the delimiter. More...
std::vector< std::string > resourcePaths ()
 Get resource paths based on latest environment variables. More...
std::string scopedName (const Entity &_entity, const EntityComponentManager &_ecm, const std::string &_delim="/", bool _includePrefix=true)
 Helper function to generate scoped name for an entity. More...
gz::sim::Entity topLevelModel (const Entity &_entity, const EntityComponentManager &_ecm)
 Get the top level model of an entity. More...
std::string validTopic (const std::vector< std::string > &_topics)
 Helper function to generate a valid transport topic, given a list of topics ordered by preference. The generated topic will be, in this order: More...
Entity worldEntity (const Entity &_entity, const EntityComponentManager &_ecm)
 Get the world to which the given entity belongs. More...
Entity worldEntity (const EntityComponentManager &_ecm)
 Get the first world entity that's found. More...
math::Pose3d worldPose (const Entity &_entity, const EntityComponentManager &_ecm)
 Helper function to compute world pose of an entity. More...
Variables
const std::string kRenderPluginPathEnv {"IGN_GAZEBO_RENDER_ENGINE_PATH"}
 Environment variable holding paths to custom rendering engine plugins. More...
const std::string kResourcePathEnv {"IGN_GAZEBO_RESOURCE_PATH"}
 Environment variable holding resource paths. More...
const std::string kSdfPathEnv {"SDF_PATH"}
 Environment variable used by SDFormat to find URIs inside <include> More...
const std::string kServerConfigPathEnv {"IGN_GAZEBO_SERVER_CONFIG_PATH"}
 Environment variable holding server config paths. More...
