gz/sim/components/JointForceCmd.hh File Reference
#include <vector>
#include <gz/sim/config.hh>
Namespaces | |
ignition | |
This library is part of the Ignition Robotics project. | |
ignition::gazebo | |
ignition::gazebo::components | |
Components represent data, such as position information. An Entity usually has one or more associated components. | |
Typedefs | |
using | JointForceCmd = Component< std::vector< double >, class JointForceCmdTag > |
Commanded joint forces (or torques) to be applied to a joint in SI units (Nm for revolute, N for prismatic). The component wraps a std::vector and systems that set this component need to ensure that the vector has the same size as the degrees of freedom of the joint. More... | |
