gz/sim/components/PhysicsEnginePlugin.hh
16 */
17 #ifndef GZ_GAZEBO_COMPONENTS_PHYSICSENGINEPLUGIN_HH_
18 #define GZ_GAZEBO_COMPONENTS_PHYSICSENGINEPLUGIN_HH_
20 #include <string>
24
25 namespace ignition
26 {
27 namespace gazebo
28 {
31 namespace components
32 {
34  using PhysicsEnginePlugin = Component<std::string,
35  class PhysicsEnginePluginTag>;
36  IGN_GAZEBO_REGISTER_COMPONENT("ign_gazebo_components.PhysicsEnginePlugin",
38 }
39 }
40 }
41 }
42
43 #endif
STL class.
Component< std::string, class PhysicsEnginePluginTag > PhysicsEnginePlugin
Holds the physics engine shared library.
Definition: gz/sim/components/PhysicsEnginePlugin.hh:35
