ignition::gazebo::events Namespace Reference
Namespace for all events. Refer to the EventManager class for more information about events. More...
using CollectContactSurfaceProperties = gz::common::EventT< void(const Entity &, const Entity &, const math::Vector3d &, const std::optional< math::Vector3d >, const std::optional< math::Vector3d >, const std::optional< double >, const size_t, physics::SetContactPropertiesCallbackFeature::ContactSurfaceParams< Policy > &), struct CollectContactSurfacePropertiesTag >
 This event is called when the physics engine needs to collect what customizations it should do to the surface of a contact point. It is called during the Update phase after collision checking has been finished and before the physics update has happened. The event subscribers are expected to change the params argument. More...
using LoadPlugins = common::EventT< void(Entity, sdf::ElementPtr), struct LoadPluginsTag >
 Event used to load plugins for an entity into simulation. Pass in the entity which will own the plugins, and an SDF element for the entity, which may contain multiple <plugin> tags. More...
using Pause = gz::common::EventT< void(bool), struct PauseTag >
 The pause event can be used to pause or unpause simulation. Emit a value of true to pause simulation, and emit a value of false to unpause simulation. More...
using Policy = physics::FeaturePolicy3d
using PostRender = gz::common::EventT< void(void), struct PostRenderTag >
 The render event is emitted after rendering updates. The event is emitted in the rendering thread so rendering calls can ben make in this event callback. More...
using PreRender = gz::common::EventT< void(void), struct PreRenderTag >
 The render event is emitted before rendering updates. The event is emitted in the rendering thread so rendering calls can ben make in this event callback. More...
using Stop = gz::common::EventT< void(void), struct StopTag >
 The stop event can be used to terminate simulation. Emit this signal to terminate an active simulation. More...
Typedef Documentation
◆ CollectContactSurfaceProperties
using CollectContactSurfaceProperties = gz::common::EventT< void( const Entity& , const Entity& , const math::Vector3d & , const std::optional<math::Vector3d> , const std::optional<math::Vector3d> , const std::optional<double> , const size_t , physics::SetContactPropertiesCallbackFeature:: ContactSurfaceParams<Policy>& ), struct CollectContactSurfacePropertiesTag>
◆ LoadPlugins
using LoadPlugins = common::EventT<void(Entity, sdf::ElementPtr), struct LoadPluginsTag>
◆ Pause
using Pause = gz::common::EventT<void(bool), struct PauseTag>
For example, to pause simulation use:
eventManager.Emit<gz::sim::events::Pause>(true);
◆ Policy
◆ PostRender
using PostRender = gz::common::EventT<void(void), struct PostRenderTag>
For example:
eventManager.Emit<gz::sim::events::PostRender>();
◆ PreRender
using PreRender = gz::common::EventT<void(void), struct PreRenderTag>
For example:
eventManager.Emit<gz::sim::events::PreRender>();
◆ Stop
using Stop = gz::common::EventT<void(void), struct StopTag>
For example:
eventManager.Emit<gz::sim::events::Stop>();
gz::common::EventT< void(bool), struct PauseTag > Pause
The pause event can be used to pause or unpause simulation. Emit a value of true to pause simulation,...
Definition: gz/sim/Events.hh:45
gz::common::EventT< void(void), struct StopTag > Stop
The stop event can be used to terminate simulation. Emit this signal to terminate an active simulatio...
Definition: gz/sim/Events.hh:54
gz::common::EventT< void(void), struct PostRenderTag > PostRender
The render event is emitted after rendering updates. The event is emitted in the rendering thread so ...
Definition: gz/sim/rendering/Events.hh:55
gz::common::EventT< void(void), struct PreRenderTag > PreRender
The render event is emitted before rendering updates. The event is emitted in the rendering thread so...
Definition: gz/sim/rendering/Events.hh:44
