VisualizeLidar Class Reference
Visualize the LaserScan message returned by the sensors. Use the checkbox to turn visualization of non-hitting rays on or off and the textfield to select the message to be visualised. The combobox is used to select the type of visual for the sensor data. More...
#include <VisualizeLidar.hh>
Signals
void MaxRangeChanged ()
 Notify that maximum range has changed. More...
void MinRangeChanged ()
 Notify that minimum range has changed. More...
void TopicListChanged ()
 Notify that topic list has changed. More...
 VisualizeLidar ()
 ~VisualizeLidar () override
Q_INVOKABLE void DisplayVisual (bool _value)
 Set whether to display the lidar visual. More...
void LoadLidar ()
 Load the scene and attach LidarVisual to the scene. More...
Q_INVOKABLE QString MaxRange () const
 Get the maximum range of the lidar sensor (in metres). More...
Q_INVOKABLE QString MinRange () const
 Get the minimum range of the lidar sensor (in metres). More...
Q_INVOKABLE void OnRefresh ()
 Callback when refresh button is pressed. More...
void OnScan (const msgs::LaserScan &_msg)
 Callback function to get data from the message. More...
Q_INVOKABLE void OnTopic (const QString &_topicName)
 Set topic to subscribe for LidarSensor data. More...
Q_INVOKABLE void SetTopicList (const QStringList &_topicList)
 Set the topic list from a string, for example 'ignition.msgs.StringMsg'. More...
Q_INVOKABLE QStringList TopicList () const
 Get the topic list as a string. More...
void Update (const UpdateInfo &, EntityComponentManager &_ecm) override
 Update callback called every time the system is stepped. This is called at an Ignition transport thread, so any interaction with Qt should be done through signals and slots. More...
Q_INVOKABLE void UpdateNonHitting (bool _value)
 Set whether to display non-hitting rays. More...
Q_INVOKABLE void UpdateSize (int _size)
 Set lidar visualization size. More...
Q_INVOKABLE void UpdateType (int _type)
 Set visual type of LidarVisual. More...
Properties
QString maxRange
 Max Range. More...
QString minRange
 Min Range. More...
QStringList topicList
 Topic list. More...
◆ VisualizeLidar()
◆ ~VisualizeLidar()
~VisualizeLidar ( )
◆ DisplayVisual()
Q_INVOKABLE void DisplayVisual ( bool  _value)
[in]_valueBoolean value for displaying the visual
◆ eventFilter()
QEvent *  _event
◆ LoadConfig()
◆ LoadLidar()
void LoadLidar ( )
◆ MaxRange()
Q_INVOKABLE QString MaxRange ( ) const
Range, the maximum distance sensed by the sensor.
◆ MaxRangeChanged
void MaxRangeChanged ( )
signal
◆ MinRange()
Q_INVOKABLE QString MinRange ( ) const
Range, the minimum distance sensed by the sensor.
◆ MinRangeChanged
void MinRangeChanged ( )
signal
◆ OnRefresh()
Q_INVOKABLE void OnRefresh ( )
◆ OnScan()
void OnScan ( const msgs::LaserScan &  _msg)
[in]
◆ OnTopic()
Q_INVOKABLE void OnTopic ( const QString &  _topicName)
[in]_topicNameName of selected topic
◆ SetTopicList()
Q_INVOKABLE void SetTopicList ( const QStringList &  _topicList)
[in]_topicListMessage type
◆ TopicList()
Q_INVOKABLE QStringList TopicList ( ) const
Message type
◆ TopicListChanged
void TopicListChanged ( )
signal
void Update ( const UpdateInfo _info,
EntityComponentManager _ecm
Reimplemented from GuiSystem.
◆ UpdateNonHitting()
Q_INVOKABLE void UpdateNonHitting ( bool  _value)
[in]_valueBoolean value for displaying non hitting rays
◆ UpdateSize()
Q_INVOKABLE void UpdateSize ( int  _size)
[in]_sizeSize of lidar visualization
◆ UpdateType()
Q_INVOKABLE void UpdateType ( int  _type)
[in]_typeIndex of selected visual type
Property Documentation
◆ maxRange
QString maxRange
read
Max Range.
◆ minRange
QString minRange
read
Min Range.
◆ topicList
readwrite
Topic list.
