Ign-rendering renderer. All ign-rendering calls should be performed inside this class as it makes sure that opengl calls in the underlying render engine do not interfere with QtQuick's opengl render operations. The main Render function will render to an offscreen texture and notify via signal and slots when it's ready to be displayed. More...
#include <Scene3D.hh>
Signals
void ContextMenuRequested (QString _entity)
 Signal fired when context menu event is triggered. More...
void FollowTargetChanged (const std::string &_target, bool _waitForTarget)
 When fired, the follow target changed. May not be fired for every target change. More...
 IgnRenderer ()
 ~IgnRenderer () override
math::Pose3d CameraPose () const
 Get the current camera pose. More...
void Destroy ()
 Destroy camera associated with this renderer. More...
math::Vector3d FollowOffset () const
 Get the camera follow offset position. More...
std::string FollowTarget () const
 Get the target which the user camera is following. More...
bool FollowWorldFrame () const
 Get whether the camera is following the entity in world frame. More...
bool GeneratePreview (const sdf::Root &_sdf)
 Generate a preview of a resource. More...
void HandleKeyPress (QKeyEvent *_e)
 Handle key press event for snapping. More...
void HandleKeyRelease (QKeyEvent *_e)
 Handle key release event for snapping. More...
std::string Initialize ()
 Initialize the render engine. More...
void NewHoverEvent (const math::Vector2i &_hoverPos)
 New hover event triggered. More...
void NewMouseEvent (const common::MouseEvent &_e, const math::Vector2d &_drag=math::Vector2d::Zero)
 New mouse event triggered. More...
void Render (RenderSync *_renderSync)
 Main render function. More...
class RenderUtilRenderUtil () const
 Set the renderer. More...
void RequestSelectionChange (Entity _selectedEntity, bool _deselectAll, bool _sendEvent)
 Request entity selection. This queues the selection to be handled later in the render thread. More...
math::Vector3d RPYSnap () const
 Get the RPY snap values. More...
math::Vector3d ScaleSnap () const
 Get the scale snap values. More...
math::Vector3d ScreenToPlane (const math::Vector2i &_screenPos) const
 Retrieve the point on a plane at z = 0 in the 3D scene hit by a ray cast from the given 2D screen coordinates. More...
math::Vector3d ScreenToScene (const math::Vector2i &_screenPos) const
 Retrieve the first point on a surface in the 3D scene hit by a ray cast from the given 2D screen coordinates. More...
void SetDropdownMenuEnabled (bool _enableDropdownMenu)
 Set if the dropdown menu is enabled or disabled. More...
void SetFollowOffset (const math::Vector3d &_offset)
 Set the camera follow offset position. More...
void SetFollowPGain (double _gain)
 Set the p gain for the camera follow movement. More...
void SetFollowTarget (const std::string &_target, bool _waitForTarget=false)
 Move the user camera to follow the speficied target. More...
void SetFollowWorldFrame (bool _worldFrame)
 True to set the camera to follow the target in world frame, false to follow in target's local frame. More...
void SetInitCameraPose (const math::Pose3d &_pose)
 Set the initial user camera pose. More...
void SetModel (const std::string &_model)
 Set the model to hover over the scene. More...
void SetModelPath (const std::string &_filePath)
 Set the path to the model to hover over the scene. More...
void SetMoveTo (const std::string &_target)
 Move the user camera to move to the speficied target. More...
void SetMoveToPose (const math::Pose3d &_pose)
 Set the world pose of the camera. More...
void SetRecordVideo (bool _record, const std::string &_format, const std::string &_savePath)
 Set whether to record video. More...
void SetRecordVideoBitrate (unsigned int _bitrate)
 Set video recorder bitrate in bps. More...
void SetRecordVideoLockstep (bool _lockstep)
 Set whether to record video in lockstep mode. More...
void SetRecordVideoUseSimTime (bool _useSimTime)
 Set whether to record video using sim time as timestamp. More...
void SetRPYSnap (const math::Vector3d &_rpy)
 Set the RPY snap values. More...
void SetScaleSnap (const math::Vector3d &_scale)
 Set the scale snap values. More...
void SetTransformMode (const std::string &_mode)
 Set the transform mode. More...
void SetViewAngle (const math::Vector3d &_direction)
 Set the viewing angle of the camera. More...
void SetViewCollisionsTarget (const std::string &_target)
 View collisions of the specified target. More...
void SetViewCOMTarget (const std::string &_target)
 View center of mass of the specified target. More...
void SetViewController (const std::string &_viewController)
 Set camera view controller. More...
void SetViewInertiaTarget (const std::string &_target)
 View inertia of the specified target. More...
void SetViewJointsTarget (const std::string &_target)
 View joints of the specified target. More...
void SetViewTransparentTarget (const std::string &_target)
 View the specified target as transparent. More...
void SetViewWireframesTarget (const std::string &_target)
 View wireframes of the specified target. More...
void SetXYZSnap (const math::Vector3d &_xyz)
 Set the XYZ snap values. More...
void SnapPoint (math::Vector3d &_point, math::Vector3d &_snapVals, double _sensitivity=0.4) const
 Snaps a point at intervals of a fixed distance. Currently used to give a snapping behavior when moving models with a mouse. More...
void TerminateSpawnPreview ()
 Delete the visuals generated while an entity is being spawned. More...
math::Vector3d XYZSnap () const
 Get the XYZ snap values. More...
Public Attributes
math::Pose3d cameraPose = math::Pose3d(0, 0, 2, 0, 0.4, 0)
 Initial Camera pose. More...
bool initialized = false
 True if engine has been initialized;. More...
bool textureDirty = false
 Flag to indicate texture size has changed. More...
GLuint textureId
 Render texture id Values is constantly constantly cycled/swapped/changed from a worker thread Don't read this directly. More...
QSize textureSize = QSize(1024, 1024)
 Render texture size. More...
uint32_t visibilityMask = 0xFFFFFFFFu
 Camera visibility mask. More...
std::string worldName
 Name of the world. More...
◆ IgnRenderer()
◆ ~IgnRenderer()
~IgnRenderer ( )
◆ CameraPose()
math::Pose3d CameraPose ( ) const
Pose of the camera.
◆ ContextMenuRequested
void ContextMenuRequested ( QString  _entity)
signal
void Destroy ( )
◆ FollowOffset()
math::Vector3d FollowOffset ( ) const
Camera follow offset position.
◆ FollowTarget()
std::string FollowTarget ( ) const
Target being followed
◆ FollowTargetChanged
void FollowTargetChanged ( const std::string _target,
bool  _waitForTarget
signal
[in]_targetTarget to follow
[in]_waitForTargetTrue to continuously look for the target
◆ FollowWorldFrame()
bool FollowWorldFrame ( ) const
True if follow mode is in world frame, false if local frame
◆ GeneratePreview()
bool GeneratePreview ( const sdf::Root &  _sdf)
[in]_sdfThe SDF to be previewed.
True on success, false if failure
◆ HandleKeyPress()
void HandleKeyPress ( QKeyEvent *  _e)
[in]_eThe key event to process.
◆ HandleKeyRelease()
void HandleKeyRelease ( QKeyEvent *  _e)
◆ Initialize()
std::string Initialize ( )
Error message if initialization failed. If empty, no errors occurred.
◆ NewHoverEvent()
void NewHoverEvent ( const math::Vector2i &  _hoverPos)
[in]_hoverPosMouse hover screen position
◆ NewMouseEvent()
void NewMouseEvent ( const common::MouseEvent &  _e,
const math::Vector2d &  _drag = math::Vector2d::Zero
[in]_eNew mouse event
[in]_dragMouse move distance
◆ Render()
void Render ( RenderSync *  _renderSync)
[in]_renderSyncRenderSync to safely synchronize Qt and worker thread (this)
◆ RenderUtil()
class RenderUtil* RenderUtil ( ) const
Set the renderer.
◆ RequestSelectionChange()
void RequestSelectionChange ( Entity  _selectedEntity,
bool  _deselectAll,
bool  _sendEvent
[in]_selectedEntityEntity to be selected, or kNullEntity.
[in]_deselectAllTrue if all entities should be deselected.
[in]_sendEventTrue to emit an event to other widgets.
◆ RPYSnap()
math::Vector3d RPYSnap ( ) const
RPY snapping values as a Vector3d
◆ ScaleSnap()
math::Vector3d ScaleSnap ( ) const
Scale snapping values as a Vector3d
◆ ScreenToPlane()
math::Vector3d ScreenToPlane ( const math::Vector2i &  _screenPos) const
[in]_screenPos2D coordinates on the screen, in pixels.
3D coordinates of a point in the 3D scene.
◆ ScreenToScene()
math::Vector3d ScreenToScene ( const math::Vector2i &  _screenPos) const
◆ SetDropdownMenuEnabled()
void SetDropdownMenuEnabled ( bool  _enableDropdownMenu)
[in]_enableDropdownMenuThe boolean to enable or disable the dropdown menu
◆ SetFollowOffset()
void SetFollowOffset ( const math::Vector3d &  _offset)
[in]_offsetCamera follow offset position.
◆ SetFollowPGain()
void SetFollowPGain ( double  _gain)
[in]_gainCamera follow p gain.
◆ SetFollowTarget()
void SetFollowTarget ( const std::string _target,
bool  _waitForTarget = false
[in]_waitForTargetTrue to continuously look for the target to follow. A typical use case is when following a target that is not present on startup but spawned later into simulation
◆ SetFollowWorldFrame()
void SetFollowWorldFrame ( bool  _worldFrame)
[in]_worldFrameTrue to use the world frame.
◆ SetInitCameraPose()
void SetInitCameraPose ( const math::Pose3d &  _pose)
[in]_posePose to set the camera to
◆ SetModel()
void SetModel ( const std::string _model)
[in]_modelSdf string of the model to load in for the user.
◆ SetModelPath()
void SetModelPath ( const std::string _filePath)
[in]_filePathSdf path of the model to load in for the user.
◆ SetMoveTo()
void SetMoveTo ( const std::string _target)
[in]_targetTarget to move the camera to
◆ SetMoveToPose()
void SetMoveToPose ( const math::Pose3d &  _pose)
[in]_poseThe world pose to set the camera to.
◆ SetRecordVideo()
void SetRecordVideo ( bool  _record,
const std::string _format,
const std::string _savePath
[in]_recordTrue to start video recording, false to stop.
[in]_formatVideo encoding format: "mp4", "ogv"
[in]_savePathPath to save the recorded video.
◆ SetRecordVideoBitrate()
void SetRecordVideoBitrate ( unsigned int  _bitrate)
[in]_bitrateBit rate to set to
◆ SetRecordVideoLockstep()
void SetRecordVideoLockstep ( bool  _lockstep)
[in]_lockstepTrue to record video in lockstep mode
◆ SetRecordVideoUseSimTime()
void SetRecordVideoUseSimTime ( bool  _useSimTime)
[in]_useSimTimeTrue record video using sim time
◆ SetRPYSnap()
void SetRPYSnap ( const math::Vector3d &  _rpy)
[in]_rpyThe RPY snap values
◆ SetScaleSnap()
void SetScaleSnap ( const math::Vector3d &  _scale)
[in]_scaleThe scale snap values
◆ SetTransformMode()
void SetTransformMode ( const std::string _mode)
[in]_modeNew transform mode to set to
◆ SetViewAngle()
void SetViewAngle ( const math::Vector3d &  _direction)
[in]_directionThe pose to assume relative to the entit(y/ies). (0, 0, 0) indicates to return the camera back to the home pose originally loaded in from the sdf
◆ SetViewCollisionsTarget()
void SetViewCollisionsTarget ( const std::string _target)
[in]_targetTarget to view collisions
◆ SetViewCOMTarget()
void SetViewCOMTarget ( const std::string _target)
[in]_targetTarget to view center of mass
◆ SetViewController()
void SetViewController ( const std::string _viewController)
[in]_viewController.Values are "orbit", and "ortho"
◆ SetViewInertiaTarget()
void SetViewInertiaTarget ( const std::string _target)
[in]_targetTarget to view inertia
◆ SetViewJointsTarget()
void SetViewJointsTarget ( const std::string _target)
[in]_targetTarget to view joints
◆ SetViewTransparentTarget()
void SetViewTransparentTarget ( const std::string _target)
[in]_targetTarget to view as transparent
◆ SetViewWireframesTarget()
void SetViewWireframesTarget ( const std::string _target)
[in]_targetTarget to view wireframes
◆ SetXYZSnap()
void SetXYZSnap ( const math::Vector3d &  _xyz)
[in]_xyzThe XYZ snap values
◆ SnapPoint()
void SnapPoint ( math::Vector3d &  _point,
math::Vector3d &  _snapVals,
double  _sensitivity = 0.4
) const
[in]_pointInput point to snap.
[in]_snapValsThe snapping values to use for each corresponding coordinate in _point
[in]_sensitivitySensitivity of a point snapping, in terms of a percentage of the interval.
◆ TerminateSpawnPreview()
void TerminateSpawnPreview ( )
◆ XYZSnap()
math::Vector3d XYZSnap ( ) const
XYZ snapping values as a Vector3d
◆ cameraPose
◆ initialized
◆ textureDirty
◆ textureId
GLuint textureId
◆ textureSize
◆ visibilityMask
◆ worldName
Name of the world.
