gz/sim/components/Actor.hh
16 */
17 #ifndef GZ_GAZEBO_COMPONENTS_ACTOR_HH_
18 #define GZ_GAZEBO_COMPONENTS_ACTOR_HH_
20 #include <gz/msgs/actor.pb.h>
21
22 #include <chrono>
23 #include <ratio>
24 #include <string>
25
26 #include <sdf/Actor.hh>
27
31 #include <gz/sim/Conversions.hh>
32 #include <gz/sim/config.hh>
33
34 namespace ignition
35 {
36 namespace gazebo
37 {
38 // Inline bracket to help doxygen filtering.
39 inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
40 namespace serializers
41 {
42  using ActorSerializer =
44
46  {
51  public: static std::ostream &Serialize(std::ostream &_out,
52  const std::chrono::steady_clock::duration &_time)
53  {
54  _out << std::chrono::duration_cast<std::chrono::nanoseconds>(
55  _time).count();
56  return _out;
57  }
58
63  public: static std::istream &Deserialize(std::istream &_in,
64  std::chrono::steady_clock::duration &_time)
65  {
66  int64_t time;
67  _in >> time;
69  return _in;
70  }
71  };
72 }
73
74 namespace components
75 {
79  using Actor =
81  IGN_GAZEBO_REGISTER_COMPONENT("ign_gazebo_components.Actor", Actor)
82
83
84  using AnimationTime = Component<std::chrono::steady_clock::duration,
85  class AnimationTimeTag, serializers::AnimationTimeSerializer>;
86  IGN_GAZEBO_REGISTER_COMPONENT("ign_gazebo_components.AnimationTime",
87  AnimationTime)
88
90  using AnimationName = Component<std::string, class AnimationNameTag,
91  serializers::StringSerializer>;
92  IGN_GAZEBO_REGISTER_COMPONENT("ign_gazebo_components.AnimationName",
93  AnimationName)
94 }
95 }
96 }
97 }
98
99 #endif
STL class.
static std::istream & Deserialize(std::istream &_in, std::chrono::steady_clock::duration &_time)
Deserialization for std::chrono::steady_clock::duration.
Definition: gz/sim/components/Actor.hh:63
static std::ostream & Serialize(std::ostream &_out, const std::chrono::steady_clock::duration &_time)
Serialization for std::chrono::steady_clock::duration.
Definition: gz/sim/components/Actor.hh:51
Definition: gz/sim/components/Serialization.hh:108
STL class.
Definition: gz/sim/components/Actor.hh:45
