gz/sim/components/Factory.hh File Reference
#include <algorithm>
#include <cstdint>
#include <cstring>
#include <deque>
#include <map>
#include <memory>
#include <string>
#include <utility>
#include <vector>
#include <gz/common/SingletonT.hh>
#include <gz/common/Util.hh>
#include <gz/sim/detail/ComponentStorageBase.hh>
#include <gz/sim/config.hh>
#include <gz/sim/Export.hh>
#include <gz/sim/Types.hh>
class  ComponentDescriptor< ComponentTypeT >
 A class for an object responsible for creating components. More...
class  ComponentDescriptorBase
 A base class for an object responsible for creating components. More...
class  ComponentDescriptorQueue
 A class to hold the queue of component descriptors registered by translation units. This queue is necessary to ensure that component creation continues to work after plugins are unloaded. The typical scenario this aims to solve is: More...
class  Factory
 A factory that generates a component based on a string type. More...
struct  RegistrationObjectId
 A wrapper around uintptr_t to prevent implicit conversions. More...
class  StorageDescriptor< ComponentTypeT >
 A class for an object responsible for creating storages. More...
class  StorageDescriptorBase
 A base class for an object responsible for creating storages. More...
 ignition
 ignition::gazebo
 ignition::gazebo::components
Macros
#define IGN_GAZEBO_REGISTER_COMPONENT(_compType, _classname)
 Static component registration macro. More...
Macro Definition Documentation
◆ IGN_GAZEBO_REGISTER_COMPONENT
#define IGN_GAZEBO_REGISTER_COMPONENT (   _compType,
  _classname
Value:
class IgnGazeboComponents##_classname \
public: IgnGazeboComponents##_classname() \
using namespace ignition; \
using Desc = gz::sim::components::ComponentDescriptor<_classname>; \
gz::sim::components::Factory::Instance()->Register<_classname>(\
_compType, new Desc(), \
gz::sim::components::RegistrationObjectId(this));\
public: IgnGazeboComponents##_classname( \
const IgnGazeboComponents##_classname&) = delete; \
public: ~IgnGazeboComponents##_classname() \
gazebo::components::RegistrationObjectId(this)); \
static IgnGazeboComponents##_classname\
IgnitionGazeboComponentsInitializer##_classname;
void Unregister()
Unregister a component so that the factory can't create instances of the component anymore.
Definition: gz/sim/components/Factory.hh:336
static Factory * Instance()
Get an instance of the singleton.
Use this macro to register components.
Each time a plugin which uses a component is loaded, it tries to register the component again, so we prevent that.
[in]_compTypeComponent type name.
[in]_classnameClass name for component.
