gz/sim/components/Serialization.hh File Reference
#include <google/protobuf/message_lite.h>
#include <gz/msgs/double_v.pb.h>
#include <string>
#include <vector>
#include <sdf/Sensor.hh>
#include <gz/sim/Conversions.hh>
#include <gz/msgs/Utility.hh>
class  ComponentToMsgSerializer< DataType, MsgType >
 Serialization for that converts components data types to gz::msgs. This assumes that gz::sim::convert<DataType> is defined. More...
class  HasGazeboConvert< In, Out >
 Type trait that determines if an ignition::gazebo::convert from In to Out is defined. Usage: More...
class  MsgSerializer
 Serializer for components that hold protobuf messages. More...
class  StringSerializer
 Serializer for components that hold std::string. More...
class  VectorDoubleSerializer
 Serializer for components that hold std::vector<double>. More...
class  VectorSerializer< T >
 ignition
 ignition::gazebo
 ignition::gazebo::serializers
 ignition::gazebo::traits
using SensorSerializer = ComponentToMsgSerializer< sdf::Sensor, msgs::Sensor >
 Common serializer for sensors. More...
