#include <LeeVelocityController.hh>
void CalculateRotorVelocities (const FrameData &_frameData, const EigenTwist &_cmdVel, Eigen::VectorXd &_rotorVelocities) const
 Calculate rotor velocities given the current frame data and the commanded velocity. More...
static std::unique_ptr< LeeVelocityController > MakeController (const LeeVelocityControllerParameters &_controllerParams, const VehicleParameters &_vehicleParams)
 Factory function to create LeeVelocityController objects. More...
This controller is inspired by the LeePositionController from RotorS https://github.com/ethz-asl/rotors_simulator/blob/master/rotors_control/include/rotors_control/lee_position_controller.h The controller can be used to command linear velocity and yaw angle velocity expressed in the body frame.
◆ CalculateRotorVelocities()
void CalculateRotorVelocities ( const FrameData &  _frameData,
const EigenTwist &  _cmdVel,
Eigen::VectorXd &  _rotorVelocities
) const
[in]_frameDataFrame data including pose and linear and angular velocities
[in]_cmdVelCommanded velocity
[out]_rotorVelocitiesComputed rotor velocities.
◆ MakeController()
static std::unique_ptr<LeeVelocityController> MakeController ( const LeeVelocityControllerParameters &  _controllerParams,
const VehicleParameters &  _vehicleParams
static
[in]_controllerParamsController parameteres
[in]_vehicleParamsVehicle parameteres
nullptr if the input parameters were valid, otherwise an pointer to an instance of LeeVelocityController
