gz/sim/components/ExternalWorldWrenchCmd.hh File Reference
#include <gz/msgs/wrench.pb.h>#include <gz/sim/components/Component.hh>#include <gz/sim/components/Factory.hh>#include <gz/sim/components/Serialization.hh>#include <gz/sim/config.hh>Go to the source code of this file.
Namespaces | |
| gz | |
| gz::sim | |
| gz::sim::components | |
| Components represent data, such as position information. An Entity usually has one or more associated components. | |
Typedefs | |
| using | ExternalWorldWrenchCmd = Component< msgs::Wrench, class ExternalWorldWrenchCmdTag, serializers::MsgSerializer > |
| A component type that contains the external wrench to be applied on an entity expressed in the world frame and represented by gz::msgs::Wrench. Currently this is used for applying wrenches on links. Although the msg::Wrench type has a force_offset member, the value is currently ignored. Instead, the force is applied at the link origin. The wrench uses SI units (N for force and N⋅m for torque). More... | |
