EnvironmentalSensorSystem.hh File Reference
#include <gz/sim/System.hh>
#include <gz/sensors/Sensor.hh>
#include <gz/transport/Node.hh>
#include <memory>
class  EnvironmentalSensorSystem
 Sensor for reading environmental data loaded from outside world. To use, add this system to the world file, then instantiate sensors of custom type with gz:type="environmental_sensor/{field_name}", where field_name refers to the type of data you would like to output. Alternatively, if you would like to specify a custom field name you may do so using the <environment_variable> tag. More...
 gz
 gz::sim
